Results 1 to 9 of 9
    Jul 20 2008
    seatown
    engine improvements...whats best
    i have an 04 1.8t automatic. what are the best upgrades for the engine that are affordable? what have you guys done to improve the cars performance?
    thanks. relatively new to my audi looking for some good mods to make!
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: engine improvements...whats best
    New air filter, I would say a K%N.
    New chip, I would say and APR 93.
    Maybe a new exhaust. Thats from Stasis.
    All together I would say around 2200-2500 dollars.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Chip, DV, exhaust, high flow cat. Skip intake
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Jul 20 2008
    seatown
    do the chips make a dramatic difference? how much does the diverter valve help? do they really add that much power...
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    from stock its a dramatic difference and if you get chipped you will eventually need a new divereter valve to hold all the extra pressure after that you should get exhaust bigger injectors after that your talking big money
    Feb 24 2004
    Land of the smiles
    Quote Originally Posted by bb1122 View Post
    Sure it does! The stock DV are known to be weak, so an upgrade replacement is recommended.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I would read the link posted above, lots of great info... here is what I did in the last few months and I am very happy with the car's performance thus far.
    Evoms Intake (like stated above sort of a waste but it sounds cool)
    Forge 007 DV
    AWE Cat back exhaust (Stasis doesn't make one that I know of for the B6)
    AWE FMIC
    Forge TIP
    GIAC FX reflash with Siemens 380cc injectors
    Stasis Street Sport Coilovers
    Adam's Slotted and dimpled rotors and Hawk Ceramic Pads
    Then some appearance mods...
    I hope that helps...
    Buncha motorcycles
    Memphis, TN
    search please!
    any big injector flash/1+ flash will net you about 60hp gain (pm Manguyen for the injectors you need). you will need an upgraded DV but you wont gain any HP, exhaust and test pipe (lots of options depending on what you want in terms of power/sound) and FMIC are your best bets
    APR Stage 2/AWE Intake
