Results 1 to 8 of 8
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    HELP!! hood latch..
    First of all let me admit I know what I did was stupid.
    I had the grille off to clean it up and paint it and when I put it back on I forgot to pull the hood latch through the hole. So I can close the hood but I don't know how I'm going to open it up to fix this. Is there an emergency release somewhere or am I screwed or what?
    Dec 05 2007
    Re: HELP!! hood latch..
    No emergency latch that I know of. Maybe get a butter knife and use it as leverage and get it through the hole (yes, a little forcing it will be necessary). You might fuber the hood latch (the rubber end piece) or even the grill, but at least you will be able to get things cleared up. If you do mess the latch up, you could maybe get one from A&P (this is a link) for cheap. If it is an RS4 grill, they are no longer cheap. But if it is OEM, I have one I can sell you for cheap. Or you might not mess anything up.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Pop the grille back out. Sounds like a bitch, but it can be done. Otherwise, find some needle nose pliers, screw drivers, whatever it takes. Just get it done.
    Aug 14 2008
    Ohio%20
    I've been trying to get it back out but it doesn't seem like it will come out without breaking it. I'm about to do it anyway.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    metal clothes hanger and loop it to pull on the latch, happened to me before
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Aug 14 2008
    Ohio%20
    Thanks for the help guys. I was able to get the grille back out using a little elbow grease. It's still not perfect, but it will do for now.
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    Dont mean to throw this off topic but i was looking for the link to the cheap rs4 grill for you and found its now $100 more then it was before. . . . When the hell did this happen? Why?
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    Dec 05 2007
    ^Yeah man, prices went up couple months ago. Cheapest place to get them is GMG for $140 shipped.
    /off topic
