Originally Posted by
Gondi Stylez
Woah, that was pretty intense!
I'm guessing you hate these things now? I was debating between RNS-E and this for a while (with the AVIC-F90) in the mix for a bit, but since my friend builds these figured why not give it a try?
What did you end up getting? RNS-E?
Heat should be okay as it will be behind my back seat (just the HD, USBs and DVD drive will be in the glovebox). How long was start up time? Would you do anything different? or would that mean not doing it to start?
What is the shut down/turn on procedure? No need to turn off computer before shutting car off and <30sec boot time with all specs, etc remembered? If I tie it into my ignition it will do as my OEM deck will?
I wouldn't say you've changed my mind but I am seconding guessing now, haha?!?!
Yes, Ill never have one ever again. I went back to my Alpine IVA-D310 that I had in the car prior to the carputer.
You need a power supply card/board with an integrated on/off controller. Its a seperate power board that will go inside the carputer housing. It will automatically turn the computer on when you start the car, when you turn the key off, it will power it long enough for the computer to do the typical "shut down" itself, then go off. You cant tie in directly to the ignition, it wont turn out without a trigger source + power and when you turn the ign off, it will just kill the computer (like unplugging it from the wall). And you wont want to manually turn it on/off directly wiring it either
Unless you love computers and F'ing with them all the time, I would highly suggest against it. Its a great idea but it definitely didnt work out like I was expecting
