Results 1 to 6 of 6
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    Exhaust gaskets?
    This may be a stupid question but I noticed that my test pipe came with exhaust gaskets and my exhaust didn't, so do I need them?
    And if I do need them any suggestions on where to get them?
    TIA
    -Ian
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: Exhaust gaskets?
    It all depends on how your old ones are! most of them will break apart when you take them out. if they didn't then you should be fine. otherwise genuineaudiparts.com i believe 034 has them too. they are pretty cheap like $10 so might as well and be safe! then you won't have any leaks.
    The usual things!!
    Resistor Install
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    Well thats the thing isn't the stock exhaust from the downpipe back one piece?? It sure looks like it. I'm replacing the exhaust from the turbo back, I have testpipe, downpipe, a mid section, and two rear sections.
    All I can find on 034's site are the gaskets for between the turbo and testpipe, and testpipe and downpipe. And I already have those.
    -Ian
    Feb 16 2008
    Oakdale, MN
    well that all you need. there are only 2. I'm not sure how many peices the exhaust is from the downpipe back. but the only gaskets you'll need are the one that goes by the turbo and the one that goes at the end of the testpipe/cat!
    The usual things!!
    Resistor Install
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    ok thanks for your help.
    -Ian
    Feb 16 2008
    Oakdale, MN
    You bet
    The usual things!!
    Resistor Install
