So I took the car for a spin around the neighborhood to see how it would feel after sitting for so long and not being driven. The boost felt good and the car felt good except for one thing. MORE OIL LEAKING!!!
When I got home and popped the hood I noticed that there was smoke coming from the exhaust area. When I checked the cam seal that I had replaced it was fine and oil free. Most of the oil is coming from below the head but I cannot see behind there to tell where it is coming from.
So here are a few questions that I need answered and any help would be much appreciated.
1) Where can oil leak from on the back side of the engine below the head? (rear main seal?... )
2) What seals are back there?
3) How hard are they to replace.
All my problems with leaking started when I started the car while the front end was jacked up, because I wanted to see if it would start. I don't know if maybe some seals dried up or shrank because the car was sitting for so long or if some seals just went bad. I also had some white smoke coming out of my tail pipe but I don't know if it's related to the oil leaking problem. I need to solve one issue at a time but I thought I would throw it out there just in case one has something to do with the other.
I just might have to take it into a shop and let them figure it out but I don't want to do that just yet. What do you guys think and any help would be appreciated ......... .......... I'll try to take some pictures if that will help.
Other than the oil leak the car felt good, so at least I have that ........
