Results 1 to 7 of 7
    Senior Member Three Rings Trv06kviper's Avatar
    Jan 02 2007
    86 Coupe Quattro
    Stumped, steering column locked up
    First time I've ever encounter this issue. Woke up this morning to turn on my car to let it warm up and the key would not turn past ACC. Jiggled the steering wheel both ways, no go. Jacked up the front end, made sure the parking brake was off, no go. Unplugged the battery left it there for a solid hour no go, only this time there is zero play in the steering wheel. I'm stumped I've asked a lot of ppl and cannot find a solution...help! (yes the wheels are turned about 30-40 degrees left and I', on a 25-30 degree incline).
    www.eurosunday.net
    Eurosunday International
    "Driven to Drive"
    Senior Member Three Rings TripleBlack's Avatar
    Aug 24 2008
    B6 3.0 Avant 6 Speed
    East Bay, CA
    Re: Stumped, steering column locked up
    How far can you move the wheel when out of the locked position?
    Remember: Your car is unique, just like everyone elses.
    Don't let your typing write checks that your body can't cash.
    034Motorsport.com
    Jan 02 2007
    86 Coupe Quattro
    Can't get it out of the locked position. I tried swapping out the ignition switch but (the electronic unit that seems to have been a problem for that model) the wheels are still locked and the key won't turn past 'ACC'.
    www.eurosunday.net
    "Driven to Drive"
    Aug 24 2008
    East Bay, CA
    Pretty sure I've had the same issue as you.
    Even though it feels like it can't turn, you can turn it just a little bit. It won't be much at all, but it'll be enough. Once you feel the wheel move just a little bit, hold it there and then try to start your car. It should do the trick.
    034Motorsport.com
    Jan 02 2007
    86 Coupe Quattro
    Tried that : ( It's something more, probably mechanical. Had one of my co-workers come over and help me rock the car a little bit to see if we couldn't perhaps get it loose (Plus, the level ground).
    www.eurosunday.net
    "Driven to Drive"
    Jan 02 2007
    86 Coupe Quattro
    Ended up getting a new ignition switch and I have a new tumbler and keys but can't figure out how to get the old key slot out to put the new one in.
    www.eurosunday.net
    "Driven to Drive"
    Jan 02 2007
    86 Coupe Quattro
    Progress...somewhat. Got the key to turn finally and the car to start but, The steering wheel will not disengage from the locked position. I've had a few people look at it now and we're all pretty much stumped! The car will have to be towed and I would really like to avoid doing so ><.
    www.eurosunday.net
    "Driven to Drive"
