Results 1 to 6 of 6
Thread: FMIC piping Q?
    Established Member Two Rings blkb6a4's Avatar
    Feb 24 2008
    2001 audi a4 1.8t quattro
    Minnesota
    FMIC piping Q?
    So I'm working on putting together everything I need for my GT3071 build and I'm wondering what size fmic piping I should be running 2.25 or 2.5 or somthing totally diff. Thanks guys
    2001 Santorin blue :91 oct APR chip, atp 3" test pipe, APR stealth cat back, "dope" rear emblem, painted grill, clear corner mod, custom center vent VDO boost gauge, H&R race, 034 Snub, 034 n75H, Southbend stg5, Stoptech stage 2, A8 fat fives, CXracing 2.25 FMIC, DDM 5k HID.
    I am currently accepting donations for my BT fund PM if your interested in helping
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: FMIC piping Q?
    for a Gt30, im gonna have to say 2.5"
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 24 2008
    Minnesota
    Re: FMIC piping Q?
    thats what I was thinking, I was going to do 28r and then didn't wanna do that many stages so I'm building the motor and slapping on the turbo this winter.
    P.S. If anyone in the minnesota twin cities area with previous knowlage wants to help build my motor somtime in the next month or two let me know, I am willing to pay you or just supply the beer for the weekend, if you have to travel i'll pay for gas and you can stay at my house...just send me a pm
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: FMIC piping Q?
    Best to match or get very close to the size outlet of the turbo. The GT3071r uses a 2"(50.8mm) outlet, so you might be better off with 2.25" so it can keep the velocity up.
    Funny thing is the Greg just went from his old FMIC that used 2.5" pipes on both sides to a ER comp that uses 2.25 on the hot side and 2.5" on the cold side. He was driving the car this weekend and just noticed that his car is making 3psi more boost then it was with his old FMIC.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: FMIC piping Q?
    Thread jack,
    Mike what are the benefits of running the larger pipes on the cold side? I dont get why not just run the same size all the way through?
    Jul 07 2004
    socal
    Re: FMIC piping Q?
    Quote Originally Posted by njm23 View Post
    Thread jack,
    Volume and the tb is larger. Velocity on the hot side to help push the air thru the core.
    They say that there is a speed range that you want to keep the air flow, if it gets too high the pipe size is a restriction and if it is too slow causing the air flow to stall the pipe is too big.
