Results 1 to 7 of 7
    Senior Member Three Rings pearl1.8T's Avatar
    Feb 12 2004
    Audi A4 1.8TQ
    Bay Area, Cali
    oem s4 suspension on an a4
    Does anyone know if this will raise the car higher than stock a4 suspension? I heard that since the s4 is heavier, the shocks will be different on the a4. I'm reverting back to stock, and am considering putting the stock s4 suspension on my a4.
    1998.5 A4 1.8TQ [19x8.5 ADR M-classic][P-Zeros][Neuspeed Race][Bilstein sports][K04][GIAC][tip chip][K&N][Hyperboost DV][APR snub mount][RS4 grill][S4 wheel liner][JVC El Kameleon][Rockford Fosgate XLC][MBQuarts][Zimmerman][LLtek fogs][6k HID]
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: oem s4 suspension on an a4
    It will cause the nose to sit about 1 inch higher.
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    ...Unless you fit just the dampers.
    Spring rates, especially the front ones, are too high for an A4.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    S4 will make it 4x4 status.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Did a sport suspension from a 2.8 on my A4. The springs made it sit exactly where the car was with the stock suspension.
    Not worth it IMO.
    Although I did hold on to and am still using the sport shocks from the 2.8 setup and just paired them with H&R springs. Looks MUCH better now.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    S4 shocks + aftermarket A4 springs look and ride good.
    TEAM|AXION
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The struts are all the same size, valving may be slightly different.
    The springs are different lengths and/on rates.
    The struts can be used on any B5 Quattro but the S4 springs are too tall even for the S4.
    Jim
    I Do Werk.
