Results 1 to 31 of 31
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    EBC won't stop building boost....Greddy Users Please help!
    So, after finally getting my EPC and CEL issue figured out (had severe intake, vacuum, and exhaust leaks ), I now have an entirely new problem....My Greddy Profec B Spec II will not stop building boost. The unit is fully functional, as it was JUST serviced by a Greddy customer service tech. Bought a new solenoid and harness, so everything is in tip top shape. I hooked up the COM port to the WG, and the NO port to a brass nipple that is welded into my intercooler pipe right off the turbo.
    Now, my initial plan was to run 15psi on low boost and 18psi on high boost (don't wanna blow my motor). So I put SET to 30%, GAIN to 5%, and i set the limit at 1.03 for low boost and 1.04 at high boost. But, whenever I drive WOT, the wastegate opens up ALL the way, boosting the car WAY over 20psi for only an instant. Whenever this happens, I IMMEDIATELY back off the throttle. So, whenever I accelerate, the solenoid valve opens up 100%, leaving the turbo to boost as much as it desires at WOT......So, I'm not sure if I've set it up improperly, or if something is wrong with either my settings or the unit itself.
    I can provide pictures of how i've got it set up, or I can explain further about how I've got things wired, but I DO think that I've got it correct, according to the instruction manual. So, if anyone out there has any suggestions PLEASE PLEASE PLEASE send em my way, because I really wanna get this thing running so I can do some logs. Thanks
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: EBC won't stop building boost....Greddy Users Please help!
    That doesn't make sense. If the wg opens all the way the boost would decrease. Maybe you meant the solenoid valve opens all the way. It sounds like the EBC is setup to allow a boost spike.
    Did you put in a start boost? You can decrease the start boost to help control boost spikes since it forces the solenoid valve to start opening sooner. This is on page 17 of the manual.
    Sep 16 2006
    '98 528i
    Sorry, I meant the solenoid opens up all the way.....my bad
    But as far as the start boost goes, I set it very low, at like .70 x100kpa or something, and it still boosts as high as it wants to. When I lower the start boost, it doesn't help....
    Can someone else out there post their settings and I'll give it a try
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    maybe try turning the set to lower percentage. What psi is your wastegate? I will post up the settings that I have on my profec B.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Jul 07 2004
    socal
    What happens when you lower the set % or when you lower the gain?
    Sep 16 2006
    '98 528i
    Not sure what the wastegate spring is set at.....but I'll try setting the percentage really low
    Jul 07 2004
    socal
    Quote Originally Posted by JumboBlack1.8 View Post
    If you turn off your EBC or bypass the motor you can find out what psi the wg spring is rated at.
    Sep 16 2006
    '98 528i
    Well, I think I might've found the problem......turned off the EBC, and went WOT, and the car did the same thing. Continued to build boost......so now, I'm assuming that my wastegate is toast.....some correct me if I'm wrong
    Apr 22 2007
    Riverbank, Ca
    Or your hose to your wastegate popped off?
    Sep 16 2006
    '98 528i
    Quote Originally Posted by andyrew View Post
    Nope, its def attached......
    Jul 07 2004
    socal
    Then it is plugged.
    You can check this buy using a new hose to go right to the WG from the pressure spot.
    Sep 16 2006
    '98 528i
    Then it is plugged.
    What do u mean by a pressure spot? Do you mean the wastegate itself is plugged?
    If u don't mind, can you explain a bit more? I'd really like to know more from an expert
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Or the ebc is broken. I bought a brand new greddy profect b spec 2, and it did the samething. Spoke with greddy and tried everything they said and still no good. So im waiting for a new one.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Sep 16 2006
    '98 528i
    Well, I was on the phone with a greddy tech a while back, and he test everything in the unit, including the solenoid, and everything was working perfectly.....Greddy doesn't normally do repairs, but he was nice enough to help me out, even tho I didn't have a receipt.....If it is the unit, I'll be devastated cuz I have no money to buy a new one....What part of your unit was defected?
    Jul 07 2004
    socal
    Pull the 2 hoses that go to your solenoid completely off from where hook up to the wg and to your IC pipe. Then take a new hose and run it from the IC pipe straight to the WG, basically bypassing the solenoid completely. Drive the car and you should only hit what ever the WG spring pressure rating. If you hit more boost then that you have a bad WG or it might just be set too tight. YOu can check to see what it is by suppling pressure with a air compressor to the wg and see how much pressure it takes to open it.
    Sep 16 2006
    '98 528i
    thanks so much mike....I'll try it tomorrow and post some results
    Feb 05 2007
    Long Island, NY
    Well I'm guessing the control unit itself is bad. They just told me to put 12v to the solenoid and hear it click. It does. And there is no real way to check the head unit. Its still under a year so I should have a new one soon. I jsut bought a mbc for like 40 bucks and put it in for now.
    Oct 30 2007
    Griffin, GA
    My settings are Set- 70% Gain- 11% Start Boost- 19.5psi Limiter set at 21psi With these settings i run a fairly consistent 20psi My wastegate is a 10psi wastegate.
    ** 2001 A4 TQM
    Sep 16 2006
    '98 528i
    Well, it turns out my wastegate had gone bad.....i did everything that mike suggested, and nothing helped. Hooked up the wastegate to an air compressor, and pumped 10psi into it, and it didn't move.....it took nearly 30psi to get it to move....So I just ordered a new one from 034, and I hope this does the trick
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    this samething happened to me and I found that my wastegate rod was tightened too tight, so I took some of the tension off it and everything was good after that
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Oct 29 2005
    10speed
    San Francisco, CA
    so, just build the motor and run high boost. Problem solved
    - Clint
    Sep 16 2006
    '98 528i
    Quote Originally Posted by aaronamerica View Post
    hmm.....well, i'll give that a shot tomorrow.....hopefully that'll work so I can cancel my order
    ohhhh.....you have no idea how much i'd love to do that......but, as u may not know, there are still poor folk left in the work
    Oct 29 2005
    10speed
    San Francisco, CA
    lol BELIEVE ME, I know how it is
    - Clint
    Jul 07 2004
    socal
    If it still opened it might just be too tight. There are 2 nuts on the arm that allow you to loosen how much tension is on the wg actuator.
    Quote Originally Posted by dirtybrd View Post
    Did someone say track? I'd go this Friday night if I wasn't running the 7200 file. ER Comp FTW. Greg, can they do a 2.5 inlet. I saw on their website that they have 2.25 hotsides. I'll need 2.5 if I do what we were discussing last night, no?
    2.5" hotside pipe is really not needed till you get to a GT35r. If you want a 2.5" hot size pipe on a competition kit it will have to be custom since the inlet on the end tank will also need to be changed. The "race series" 800hp fmic that ER makes for the B5 uses 2.5" pipes on both sides.
    Sep 16 2006
    '98 528i
    Now its not opening at all.....Dunno if I did something wrong.....but I've got a new one on the way anyway, so I'll have to wait a couple days for it to get here
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Can you remove the WG actuator easily on the 2871R? The K03 has to be removed in order to do so. Hopefully when you remove the actuator, the wastegate flap will move freely.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Sep 16 2006
    '98 528i
    It wasn't that easy to remove....I had to take the turbo off of the manifold and the downpipe...the oil and coolant lines are still attached, but I had to unbolt it to get to the wastegate....fortunately, the wastegate flap does still move freely
    I'm actually gonna start looking for a new turbo, cuz I really have lost all confidence in the one that I bought. I made the mistake of going the cheap route, and might have bought a bad one. Even tho it boosts still, i'm not sure how much longer it'll last.....So if anyone out there has one, or knows where I can get one, please lemme know
    Jan 21 2006
    6MT BT Avant Ti
    RI
    How about a nice 3071R
    Drive it till you break it. If it boosts and don't leak oil then it does what its supposed to do; work.
    Sep 16 2006
    '98 528i
    True true.....well, it doesn't leak oil.....yet....but I'm definitely still gonna keep my eye out....I might see if I can find a GT3071r wg, cuz I don't want to change my plumbing, and it'd obviously be nice to have more power when I get around to throwin some rods in
    May 31 2005
    Dallas
    I'm almost sure thats what the problem is, I had the samething happen to mine
    Sep 16 2006
    '98 528i
    Well, given the fact that the wastegate isn't opening at all anymore, regardless of what kinda air I push through it, I'm gonna assume its done for.....I already ordered the new one, and it'll be here in a day or so....hopefully that'll fix the problem....THEN i can start tackling my serious AFR and idle issues
