Results 1 to 2 of 2
    Deactivated Four Rings
    Nov 19 2006
    MMM
    Someone verify this for me. F6DTC on a K04
    Ok, normally I wouldn't post a thread like this but last time I used the wrong spark plug I ended up machining my head...
    I'm currently running BKR7Es on my PC-16 setup. They're alright, but from my experience with them its a lot of guesswork with gapping them. Right now they're misfiring at high load/boost. I've decided just to go with a three prong setup, since that is what the AEB came with originally, no gapping, its supposed to burn cleaner, yadda yadda.
    Is the F6DTC the correct heat range for my PC-16 setup?
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Re: Someone verify this for me. F6DTC on a K04
    I believe that those plugs are 1 step colder than stock, you want to go with the coldest plug you can without fouling them. I think that the Bosch F6DTC would be a good alternative to the BKR7E's
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
