Results 1 to 4 of 4
Thread: Wheel Spacer ?
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Wheel Spacer ?
    Is anyone out there running 15mm spacers? I ask because I just got 18x9.5" BBS CHs and with the meaty tires they rub on the control arm so I decided instead of getting new tires I'll just go the spacer route. My concern is spacers could cause stud failure and I'd rather not have my wheel pass me while I'm on the highway. Thanks in advance.
    Apr 25 2007
    millersville, maryland
    Re: Wheel Spacer ?
    25mm spacers for months now no issues. As long as you get the correct lugs there will be no issues.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Wheel Spacer ?
    Quote Originally Posted by keeganhartman View Post
    Also make sure you get hub-centric spacers.
    Jul 04 2008
    York, PA
    Re: Wheel Spacer ?
    Where did you get your spacers? I'm thinking about going with the ECS kit. They say the bolts are made to work with OEM wheels, does anyone know if they will work with BBS CHs?
    http://www.ecstuning.com/stage/edpd/...heel%20Spacers
