    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    New boost after FMIC
    My boost used to hit 17psi and taper to 15 every time. After a FMIC (JHM/Ebay style) my boost was weird at 14 tapering to 10 psi. A few tweaks later I was at a pretty consistent 15psi but now I am climbing up to 19 psi at WOT. I had some boost leaks due to the clamps and have been trying to pressure test but I just tore my y-pipe plug and can't do it until tuesday. Am I still leaking most likely and the car is overboosting? I have never had a leak before.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: New boost after FMIC
    The addition of an FMIC could result in different boost. However 10psi seems like quite the loss of boost. Your best bet is to do a leak test.
    Stage 3+ RS6's
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    in 3rd gear and above, I can only get 18-19psi max. in first gear though, it would only be like 13, and in 2nd, like 14 max tapering to 10-11 by redline. I think it may be because of a MAF on its way out though.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Dec 10 2006
    Wisconsin
    FYI,
    Jungs4 and I did ours at the same time in the same garage. Matt, mine is doing exactly what yours is doing 1st, 2nd and 3rd + are all different just like yours. The car is running like a raped ape though!
    Also, my new VAST EFK is making the aux AC fan stay on for a long time....too long for my liking. Gotta call Prince on Tuesday and see what I did wrong.
    Wings
    Carbs
    Titaniums
    Dec 10 2006
    Wisconsin
    Quote Originally Posted by deb38 View Post
    It isn't hitting 10 psi anymore now that I found some leaks. I have GIAC XR.
    Wings
    Carbs
    Titaniums
