Originally Posted by
Militant-Grunt
http://www.ultrarev.com/product.php?productid=80211
Wondering if anyone is running this clutch in their car. My toy is going to be 2.0 and 35r hence I'm looking for a clutch that I won't destroy quickly. The price on the CM is steep though.
I heard good things about south bend stage 5 as well. Looking for a totally streetable clutch that wont destroy my leg.
Mike, what clutch are you running on your car?
I run a old WOA custom 4800 lbs dual diaphram 6 puck, but I plan on trying out the FX600 or FX700. If you want one let me know, I am offering them at a very low price and includes shipping.
pac1085
also, this isnt the clutch if you are afraid of a light weight flywheel.
the flywheel weighs 6 lbs
the entire assembley weighs 15 lbs.
keep in mind that with a normal clutch, the pressure plate is rather heavy. this pressure plate weighs under a lb since its aluminum. the whole thing is probably half the weight of my old setup (9 lb flywheel, 6 puck & pressure plate)
CM claims it is 8 lbs(17 lbs entire assembly) for the Billet Aluminum flywheel. CM is making a Billet Steel flywheel for us that will be 14 lbs(23 lbs entire assembly), this will be an option that we will offer for a small price.
SurferForever
Your old setup by your numbers equals 15 pounds. you jst said the who assembly weighs 15 pounds . . . im confused
He said the FX600 total weight of twin plate and flywheel was 15 lbs, which was half of the weight(30 lbs total) of his old setup that used a very light weight 9 lbs flywheel. A standard clutch setup(pressure plate and disk) for our car is around 20-25 lbs, so add that to his 9 lbs flywheel and you end up with 29-34 lbs total.
You might be confused because you think he said 9 lbs flywheel plus 6 lbs disk, when in fact he said 6 "puck" which is the type of disk not the weight.
(correction) Just looked up one of my old orders for a stage 4 and 15 lbs flywheel, total weight for the box with both of them was right around 30 lbs. This puts the clutch kit right around 14-15 lbs.
Nice part about the twin plate setup is that not only is it lighter, the weight is much closer to the center since the clutch is much smaller in diameter.
O2VW1.8T
hopefully my FX700 will be here for my Gti 1.8T, i'll test it out lol 35r + 40psi. Yes its expensive but i've seen evo tilton twin disks for 4500
You plan on running big slicks, because that is the only want you can compare a clutch setup on a FWD to one on a AWD.
