Hey Guys,
So this weekend I was driving home, and my passenger side rear window did not want to roll up. I opened up the door, to at least get the window back to the normal "rolled up" position, and found this pulley/wheel:
Found out this weekend that the piece comes from the top of the window regulator (Thanks Mike!) and controls rolling up and down:
You can see the wheel under the yellow circle.
But my 2 questions are:
1. Can a broken regulator knock out my power window motor? When I opened up the door to get the window up, I removed the motor from the regulator and tried rolling the window up and down....NOTHING happened, no noise, or movement of any kind from the motor. Is there a fuse or something that can be replaced inside the motor?
2. Are all the power window motor's the same? My buddy has an extra one for the front windows, I was going to see if they are interchangeable for the rear? (SO I could use it!)
Thanks in advance everyone, hopefully I don't have to fork over a lot of $$ for a new power window motor. =(
--Asif
