I was surfing a came upon these, at UniversalAirSuspension.com They are called "Coilover Bag & Brackets, I think they just attached to existing coilovers, where they can adjust the spring rate on fly. I'm interested for the sole purpose of raising the car for speed bumps, driveways, etc. They look pretty plug & play, but I have no air suspension knowledge, so could someone chime in on this. Thanks.
Item Description
Air Assisted Coil-Over Bags for your Existing 2" Coilovers
Benifits:
Adjustable Spring rate on the Fly (0-3,000 lbs)
6" of Forced Articulation
Higher Ground Clearance
Prevent Roll-Over
Increased Traction
Increased Handling
Fail-Safe Reliability
Reduce Viberation
Smoother Ride
Adaptable to any 2" Coil-over (must specify)
Designed for any standard 2.5" Coil
Brackets Designed for your coilover!
1/4" NPT Air Port
Please note that this kit does Not come with coilovers.
Clicky Click
