Results 1 to 12 of 12
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    how to repair a tubeless tire?
    Drove 4 hours here to lake tahoe, found that my tire deflated the next morning, thought it was the altitude, so I went to chevron put some air in it, held up well during the day yesterday, but this morning found it flat again. Tire is kumho AST ku25 225/40/18. What's my best solution for fixing it?
    2018 Mercedes GLC 300
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: how to repair a tubeless tire?
    Find the leak and go from there....
    Apr 22 2007
    Riverbank, Ca
    Take it to a tire shop. Who do you use for tires/ext? If you use them alot and your in there books they may do it for free (like American Tire)
    Is the leak on the sidewall or the tread? If its on the sidewall, new tire time.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    If it is a performance tire you want to go with a patch on the inside of the tire. Discount/american tire will do it for free. If it was just a normal tire you can use a plug.
    Los Angeles, CA
    Unfortunately there is no discount/american near where i am right now, i am about 4 hours from home so i guess i will have to use the spare for now, and take it a tire shop up here and see whats going on. I really do not see any nail punctures on the thread.
    Registered Member Two Rings 37doc's Avatar
    Oct 24 2007
    B7 S4,03 R1,04 Taco 4wd,75 RDs
    Southern Maryland
    take the wheel off , put air in the tire and use a spray bottle, hose , cup ,ect with water to find the leak, if you add a little hand soap it will really bubble when it gets on the leak, also check your valve stem and schrader valve....
    05.5 B7 S4,silver,6MT, black leather recaros,Carbon,Bose, cold weather,AWE DP's, Neuspeed cat back, GIAC 93/stock,Neuspeed short shift,BMC filter, RS4 pedals,shift boot/knob,and e-brake handle,DTM carbon rear spoiler,TCarbon rear valance,Kerscher DTM carbon splitter,DTH carbon engine cover, RS4 Optic grill, H&R swaybars,Hella optilux xenon H11 fogs,ECS snub mount,VMR 18" RS4's,stoptech F/R SS brake lines,Audi Rear sunscreen.
    Oct 24 2007
    Southern Maryland
    windex or window cleaner will work well to and its already in a convienient spray bottle !
    Oct 24 2007
    Southern Maryland
    if the puncture is in between the outer most tread grooves you can repair it, if its from the groove towards the sidewall no one will repair it , most respectable shops have the more modern patch plugs that pull through the tire from the inside out.
    Jul 07 2004
    socal
    carson city is only 1 hr away if you need to find a tire shop. There is also Les Schwab tire shop in Tahoe City.
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Agree with all suggestions above to find the leak. Suggest you over-inflate by 5-10 psi to assist with the leak location. Check your valve stem using the same methods. The soapy water/windex trick not only bubbles, but the wetting agents assure water gets onto all of the surface area of the tire.
    San Jose, CA
    andyrew and mike are correct. americas tire will talk care of you for free. you want to get a patch on the inside of the tire and a plug to fill up the whole in the tire. what you can also do is get a gas station plug to stop the leak and when you come back to town take you tire to americas tire and they will pull out the gas station plug and install a new plug with a patch. you might just have a bad valve on the wheel. air up the tire to 35-40spi and spray the valve see if any bubbles come up.
    Apr 22 2007
    Riverbank, Ca
    Put on the spare, its a full tread spare so you can run it for a while.
    OR buy an air compressor. Get a good one and keep filling your tire every hour.
    I assume your leaving tahoo tomorrow? Call an american tire about 3 hours before your ETA, tell them whats up and that you want to try and be in and out and if they can schedule you in. they'll tell you to "Just bring it in and we'll take care of you" but tell them you want to make an appointment so you can be in and out in 1/2 hour. Drive in on your spare, if they take care of you imediately you'll be running on your patched tire in 20 mins..
    Patched tires are perfectly fine to run on and my 18's have 1 patch in every tire. I even autox'ed on them (I have 16's with sticky street rubber now..)
    GL!
    Andrew
