Results 1 to 19 of 19
Thread: Alternator
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Alternator
    Anyone ever have to change their alternator. My battery cannot keep a charge and after a quick test at the local auto store it seems like my charge system is a little lower than normal. After reading Dirtybrd's thread I'm gonna check fuses tomorrow, but then I think I may need to swap the alternator. Any thoughts or on experiences with this? I'm getting the little battery "pop-up" notice when I'm driving.
    Some fast things and some slow things
    ~Josh~
    Apr 12 2007
    Milwaukee
    Re: Alternator
    hmm Audi alternators are very durable and high output. you can check the voltage regulator first.
    Jun 30 2007
    Raleigh, NC
    Re: Alternator
    haven't done it on the a4... but to me it looks liek you just pop off your intake manifold (to have more room) and then go at it with the belt tensioner and the bolts holding the alternator in like on any other car. just a few basic wires after that - then reverse your steps
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Alternator
    Hit up Dougyfresh, I think he has a spare one.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Oct 31 2005
    Virginia
    Re: Alternator
    Thanks
    ~Josh~
    Feb 17 2004
    Liberty Hill, TX
    Re: Alternator
    since you need to remove the alternator in order to replace the thermostat, I'd recommend the thermostat replacement tech article as a good starting point </shameless self-plug>
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: Alternator
    I have a spare one too if you need it. http://www.audizine.com/classifieds/...0&ppuser=15259
    Oct 31 2005
    Virginia
    Re: Alternator
    Thanks for the link Condo. I'm still trying to figure out if I need to change the alternator. I went through the fuses today and had one out but it was not a important one so now its on to the next step.
    ~Josh~
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Alternator
    your car is a mess lol
    - Clint
    Oct 31 2005
    Virginia
    Re: Alternator
    I hear you on that one, it's a big pain in the ass.
    ~Josh~
    Mar 21 2006
    Lakeland, FL.
    Re: Alternator
    At least it runs...burn!
    I'm back bitches!
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Alternator
    if your voltage regulator is going out, grab a digital multi meter and put it on AC volts, and put the leads on your battery +,-, see if there is a high amount of AC voltage across your battery. or it could be your battery itself, check the level of your battery.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Oct 31 2005
    Virginia
    Re: Alternator
    Thanks, I know its not the battery since I've changed that twice, but I have not looked at the regulator. Good info all around.
    ~Josh~
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    Re: Alternator
    Quote Originally Posted by B6Lovin View Post
    Shouldnt need to remove the intake manifold.. possible the TB though..
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Jun 30 2007
    Raleigh, NC
    Re: Alternator
    Quote Originally Posted by Redgoat View Post
    yeah, im used to mine now -- it covers EVERYTHING lol
    The Awesome™
    Oct 31 2005
    Virginia
    Re: Alternator
    how will I know if the voltage regulator is going bad, I got the little green battery pop up display when I was driving
    ~Josh~
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Alternator
    Quote Originally Posted by Condo View Post
    Mine came off a TT225HP so I'd have to do some research to see if it fits. Come to think of it. I don't think the bolt holes line up. If you need an alternator contact John (condo)
    You can remove it without touching the intake manifold or anything else. Might have to remove your throttle body though but I can not remember. Its four bolts (5mm allen head socket). The serpentine belt can be removed by moving the tensioner with an 18mm wrench (clint ). Then a 13mm socket to remove the main wire and there is a second wire that has a quick connector on it. Then you've got an alternator in your hands. Pretty simple job.
    -Doug
    Oct 31 2005
    Virginia
    Re: Alternator
    thanks i bought condo's and hopefully this will be the fix
    ~Josh~
    Jun 23 2008
    Re: Alternator
    Doug, do you have a DIY on this? I'm 99% sure my alternator crapped out on me today and need it fixed ASAP with a new Valeo.
