Results 1 to 31 of 31
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    A set of VMR wheels with varying weight?
    I ordered and received a set of VMR v708 wheels in 18/8.5 et 38. They were delivered in 2 big boxes each contains 2 wheels in their Velocity Motoring boxes. I noticed in the tracking delivery information that one of the boxes weighs 63 lbs and the other is 43 lbs?? I even noticed when they were in the big boxes that one was heavier than the other but when I got them out they were all the same size and looked exactly the same but i couldn't really tell a difference in weight between them. I wish I had a scale to weigh them. Any idea as to what is going on??
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Re: A set of VMR wheels with varying weight?
    You should weigh them before you mount them. If they do have different weights you probably need to return them If the wheels weigh different it will effect the quattro system and handling of the car
    Nov 16 2007
    Westerly//Providence
    Quote Originally Posted by Nico View Post
    x2
    Veteran Member Four Rings bsrpilot44's Avatar
    Feb 25 2007
    B7 S4
    So.Cal
    Quote Originally Posted by CoreyRandmetz View Post
    x2
    x3
    Senior Member Three Rings Stak3407's Avatar
    Sep 27 2007
    2006 Audi A4 Silver
    Munster IN
    Its shipping!! It can't be the wheels! They would not have that big of difference in weight. VMR would not be this successful.
    APR 93, Magna Flow Custom Exhaust, Stasis Coilovers, Velocity 18" Rs4 replicas, OEM S4 Door Blades, Votex Chin Spoiler, Votex Rear Spoiler, Painted Rear Valence
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Did one have the lug bolts inside?
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Quote Originally Posted by Stak3407 View Post
    Actually I got these wheels from modbargains.com. But they are advertised as VMR wheels and all the boxes say velocity motoring and they're made in Taiwan so I'm hoping they're legit. I hope the varying shipment weights is just an error from Fedex although I doubt it. Oh well looks like I'll have to wait until Tuesday to see.
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Quote Originally Posted by enigma1406 View Post
    non of them have lug bolts. I thought I can use the factory lug bolts? Should they have been included?
    Sep 17 2006
    Houston, TX
    You probably can use the stock lug bolts. I got my old wheels from VMR and they came with lug bolts. You should probably ask them.
    Jul 27 2008
    long island
    you can use the factory lugs. I think the rims weigh around 26 pounds each, but i am not sure
    May 11 2008
    Naples,FL
    stand on a scale and weigh them with yourself...
    2.0 T Quattro - 20% tint,hardwired 9500i,alpine 757 amp,alpine 12" type r sub,RS4 Sway,Giac X-chip, VMR 19 710's wrapped in Conti Extreme DW, H&R Coilovers .
    Jul 14 2008
    Stockholm - Sweden
    check the air pressure
    Current:
    - Audi TT Roadster MK3 2.0TFSI Quattro S-line (2015)
    Sold:
    - Audi A5 Convertible 2.0TFSI Quattro S-line (2012)
    - Audi A5 Coupé 3.0TDI Quattro S-line (2008)
    - Audi A4 Avant 2.0TDI B8 Quattro S-line (2008)
    Jun 13 2008
    02 b5.5
    just pick them up you will be able to notice the difference of 20 pounds...
    Jan 06 2008
    Dacia Sandero
    Arizona
    Dont think VMRs are made in Taiwan...
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by F.An View Post
    air is weightless.
    Nov 12 2007
    Grand Junction, CO
    Then explain barometric pressure.....Air is most definitely not weightless.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    hahaha owned by the weatherman. :D
    fromGMCtoAUDI, If you have a normal human weight scale at home, you can check the weight of each wheel. Just take note of your weight without the wheel and your weight with the wheel while you're holding it. Take the differences and it should all come out equal.
    Veteran Member Three Rings volcomic's Avatar
    May 10 2008
    B9 A4
    Kirkland, WA
    Quote Originally Posted by AudiWxGuy View Post
    Word. Check this out A simple example
    All of that aside, Auditude2.0T's right. The air pressure isn't really going to effect the weight (not by 20 lbs anyways)
    ◊ 20x10 Avant Garde M590's - Brushed Clear ◊ 255/30-20 Hankook V12's ◊ H&R VTF Suspension ◊ APR Tune ◊ ECS Luft-Technik Intake ◊ ECS Carbon Fiber Front Lip Spoiler ◊ ECS Carbon Fiber Grille Accents ◊ Color Matched Reflectors ◊ 15% Tint ◊ 2 JL Audio 12w6V2's ◊ JL Audio 1000/1 Amp ◊
    Jul 14 2008
    Stockholm - Sweden
    Quote Originally Posted by Auditude2.0T View Post
    air is weightless.
    Do you know what 1 bar is? Thats 1 kilogram! that is not weightless. I got 2.8 - 2.9 bar in my tires. Thats almost 6kg of air in two wheels. Thats 13 pounds. Realy not weightless.
    Current:
    Sold:
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    air is weightless.
    Oh jease
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STÃSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    barometric pressure has to do with density of air too - if density of air within the tires are same as that surrounding - it'll weight almost exactly the same
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    maybe a small taiwan man is in one of the other boxes trying to get to the US
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Nov 12 2007
    Grand Junction, CO
    Quote Originally Posted by 47Ronin View Post
    What?
    Your first statement in correct. That's why colder air typically has higher pressures. ie, a high pressure system is going to enter the northern tier of the country this week at 1050+mb. That will bring some of the COLDEST air in years to many areas of the country.
    I have no idea what the second half of your statement is trying to.......well, state.
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    Quote Originally Posted by 4RingRook. View Post
    i think they are.
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Shipping issue most likely, no way it can actually have that much of a difference. My company ships a lot of packages every day, and sometimes they don't verify if we type the weight wrong :/
    (actually most of the time they don't)
    2008 Phantom Black TQM
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Quote Originally Posted by fromGMCtoAUDI View Post
    Yes, you can reuse your factory lugs. Unless they changed the design, however, you'll find that your stock lug wrench is too large to fit the openings and that you'll need another socket wrench to get your lugs on and off
    Oct 27 2008
    Studio City, California
    i got my VMR 708 wheels from Modbargains.com aswell the stuff ships from velocity itself not from mod bargains. as for your wheels i think your fine..
    Oct 19 2008
    fl
    Why are we talking about barometric pressure? I don't think his wheels came with tires mounted and inflated......
    Nov 12 2007
    Grand Junction, CO
    You can get them from VMR M+B ready for install.
    Jul 14 2008
    Stockholm - Sweden
    Quote Originally Posted by Alky View Post
    I got my with tires and already inflated. ready to go. had to fil like .5 bar though...
    Current:
    Sold:
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Quote Originally Posted by fusionx View Post
    HEHE! I can picture him! Oh the joy when you opened the box!
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
