Results 1 to 9 of 9
    Senior Member Three Rings Avant1.8BT's Avatar
    Nov 05 2006
    mycar
    Oil Return Line....help...
    I recently just did a motor swap with a new built motor because my old motor blew up. when it blew part of my block damaged my oil return line, i call up atp turbo and ordered a return line for my 2871r elim turbo and they sent me a braided stainless line and im not sure how it connects to my turbo/oil pan. one end is just a fitting and the other end has an adapter so it looks like it will line up to the oil pan or the turbo but for the other end im not sure what to do? it seems like they want me to tap my oil pan and just screw in the fitting? any help...
    Nov 05 2006
    mycar
    Re: Oil Return Line....help...
    TTT
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    post a picture
    ::2002 S6
    Nov 05 2006
    mycar
    Quote Originally Posted by TQMB5 View Post
    post a picture
    pic should work now.
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    they messed up - it happens pretty often - that is why i don't deal with them call joe at axis motorsport - or anyone but atp
    the one side you have a fitting is to the pan the other side is just nothing - you need a gt28 adapter
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by aytheory View Post
    ditto.
    happened to me twice already with just simple orders, missing parts or wrong ones.
    won't ever use them again.
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    i actually have what you need, i accidentally bought two of them, pm me your info
    ::2002 S6
    Nov 05 2006
    mycar
    thanks guys, what should they have sent me? some one mind posting a pic and its the 2nd time they messed up my order. first time i took my car apart at a friends went to install my big turbo and they sent me the wrong one and i had to rock oem for 6 months. sucked.
    Oct 28 2006
    and a 45 deg bend to the turbo
    and the fitting you have goes into the pan
    this is what the other end should look like - and they should have given you a longer line so you can cut to length -
