The intended subs are either the Polk Momo 8" DVC or the newer Polk MM8 marine drivers. Depending on how an old connection comes through for me these could be kicked to the curb for a set of Klipsch Reference drivers.
Polk MOMO driver.
Polk MOMO front component set.
These will probably go up front. They would go in just like this as coax drivers. This makes sense from both a volume and time alignment point of view. From the driver's seat the right speaker is twice as far away as the left one. The right one is then aimed at the driver's head while the left one is aimed at the passenger's head. For the driver the off axis response of the left speaker will make it seem half as loud as if it was pointed right at you. Since it is closer but quieter and the right is farther but louder they both seem to be playing the same volume. Same goes for all the passengers without touching the balance control. Aiming stock speakers this way will often sound better than great aftermarket speakers still aimed above your shins like the stock speakers. The stock placement aims them at the base of the windshield.
Pol MM Ultra Marine sub with grill. This whole thing would be countersunk and smoothed to look like the best stock system ever.
Polk MM info:
White Paper info:
Designed To Perform Introducing the new Mobile Monitor (MM) Series high performance loudspeaker systems, the next generation in mobile loudspeaker design. The MM Series features 18 new models, including 3 Ultra Marine designs, to fit virtually any application on land and water. The MM Series is composed of 6 full range systems, 3 component packages and 9 subwoofers. As a result of 3 years of Polk research and development, the new MM systems have been designed to offer unparalleled sound quality with exceptional fit to meet virtually any application. Borrowing technology from our flagship SR Series, the MM Series offers exceptional value for the price. Through the use of high-tech carbon composite baskets, powerful Neodymium motor structures using oversized voice coils, and state-of-the-art woven glass composite cones, we offer high-end audio performance normally found only in the most expensive loudspeaker systems. In addition, these space age materials offer weight savings that can mean higher performance for your car or boat.
FEATURES
* Space Age Materials reduce weight of components while offering rock solid reliability, advanced looks and ultra high performance.
* Neodymium Magnets a rare earth metal offering exceptional strength to performance ratio, found only in the most exotic speakers, saves tremendous weight. Don’t let the sound system weigh your vehicle down.
* Carbon Composite Basket based on the spokes of a wheel is lightweight, will not flex during peaks and looks great! Don’t be afraid to show off the back of your woofer.
* Klippel Optimized Components using a state-of-the-art Klippel Distortion Analyzer, Polk engineers were able to optimize the woofer’s motor structure, voice coil alignment and suspension for the best possible performance, even at extreme listening levels.
FULL RANGE SPEAKER FEATURES
* Woven Glass Composite Cones feature tremendous stiffness-to-mass ratio. Lower mass means faster transients and finer detail.
* Large-Diameter Voice Coils (30mm) in drivers increase reliability and power handling capacity.
* Swivel Mount Tweeters (coax models only) allow precise aiming of sound.
Price Point: $120 - $350pr
The amplifier could be a 4-6 channel like Polk PA1100.5, MB Quart NAA655, JL A6450 or A/D/S.
Quart NAA-655
Polk PA1100.5
