Results 1 to 4 of 4
    Active Member One Ring sphinx's Avatar
    Mar 09 2008
    '03 A4 1.8T Quattro
    Georgia
    Did a search still need help
    Me and a buddy are doing the clear corner mod today on his 02 A6, and my 03 A4. I have the DIY for the A4, but just curious if it is the same steps for the A6. From the two threads I found it sounds a little different, but they are just to vague. We have the lights out of the A6 already just need help getting the orange markers out. Thanks in advance.
    Matt
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Re: Did a search still need help
    Here is a good thread
    http://www.audiworld.com/tech/ext.html
    Look under A6, clear corner mod for dummies
    You can also use the oven or heat gun method to pry it apart, which ever you feel more confident doing?
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Use a hairdryer. That will soften the rubber/glue so you can pull the face off. Then make sure to use a flex silicone to put back together. You will still have the origional material still there so reheat with the dryer and press firm then use the now silicone to prevent moisture.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    best way to get the amber piece out if you have the headlight in your hand is to do the following:
    take out the blinker bulb. with your finger, apply pressure until the amber piece pops off. its held in by clips. once the amber piece is free, there should be 3 screws holding in the projector lens. un screw that and slide the lens out of the way. shake the housing until the amber piece falls out of the hole for the lens. easiest way imo. no drilling or prying apart the headlight or baking anything.
    good luck!
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
