ok here is my problem: my ABS has been activating at slow speeds for the last 30k miles or more. i have cleaned the sensors multiple times, i have replaced two of the them that looked suspect, i have replaced one tone ring/cv joint, had the ABS module rebuilt cause it was flashing the light at me. after all of this it still does it at every stop. i have a VAGCOM tool on my laptop but there is no error code set in the ABS module with an intermittant or anything. So the question is can i use the vag tool in real time (driving down the road) and look at the sensor readings to the ABS module and see which one(s) is causeing the problems? if so, how?
the car is an early build 98 1.8t quattro 5speed.
it is getting completely annoying and i hate spending $140/each to replace sensors.
-jkern
