Results 1 to 10 of 10
    Mar 29 2005
    MKE
    What Sensor is that?
    There's a sensor leaking air when I hook the car up to the smoke machine...
    Located on the back of the passenger side head. Seems like it's pissing oil too, as the back of the block there is pretty grimy. I was going to install a new one, but if it requires pulling the motor, i might need some GT25s also
    B8S4|P+ 6spd, AWETouring, RocEuro, H&R OE/Bilstein/034 RSB, APR Stg2 DP + CPS, TSW Bathurst 19x9.5, Michelin PSS
    Past:B5A41.8TQM, APR, celebrations, HID retrofit
    B5S4 6M|APR stage2+, APR catless DPs, APR exhaust
    B7A42.0TQM S-line, APR 2+, RS6 18"s, RAI cat, AWE exhaust
    BMW 540i-6M|BMW 528i|93 Maxima SE|383 Camaro Z28|Jeep WJ|11 Frontier Crew 4x4|06 Saab 9-3 Aero|01 Saab 9-5 Aero|06 Acura RL
    99 Yamaha YZF600R|05 CBR F4i|01 Aprilia RST1000|99 Ducati ST2
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: What Sensor is that?
    pics... a sensor leaking oil? maybe a cam seal? not a sensor, but they are on hte back of the head and tend to leak oil
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    i think he might be talking about the cam tensoiner. Its right behind the passenger head and it has a sensor that attaches to it. there's a half moon and tensioner gasket you need to replace there. Pull the valve cover off and you can get to it. Your going to need a special tool to compress the tensioner. take it to the dealer if you have the cash. No need to pull the motor.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Mar 29 2005
    MKE
    she leaked a bit of oil off that, and i can't figure out what would cause it to leak smoke when it's on the smoke machine. need a new intake gasket or something ?
    Feb 09 2006
    Huntington Beach
    Sweet.. I was right. You need this http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T Its called the cam tensioner gasket. Get two of them.
    then get this http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T Its called a gasket under Maintenance engine. get two of them as well. replace both sides and you should be good to go. your going to need a special tool so the you can compress the tensioner. Do a search and you'll find it, i coulnt
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    or just get this and the tool rental is like $8
    http://blauparts.com/proddetail.asp?prod=GF21002
    Aug 06 2008
    Canadia
    don't even need that tool unless your removing the chains, which you also don't need to do, i just replaced those seals on both sides without it.
    Mar 29 2005
    MKE
    would be a good idea to replace the sensor as it is leaking... anybody know where i can get one ?
    Feb 09 2006
    Huntington Beach
    Quote Originally Posted by greenz View Post
    Its not the actual sensor thats leaking just so you know. Its the gasket thats seperating it from the head. the sensor is fine. Run vagcom, if you get no codes for your timing chain then the sensor is fine.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by MacDaddy View Post
    same here. u dont need that tool.
