Originally Posted by
k-f-j
Ive search but I cant seem to find a guide on how to replace the pads on a B7. I changed the pads on my B6 with out a problem using the audiworld.com guide. Can someone point me to a guide on how to take the caliper off? Is it the 4? screws on the back of the front caliper? Thanks
Comes off by removing the two bolts on the back of the caliper. There are plastic caps over the bolts. The single piston front calipers slide on these bolts. If you need a guide, there may be one in the B6 S4 forum (we have the same caliper as the B6/B7 S4, just smaller rotors). You also need to remove the spring clip from the front of the caliper.
