I'm in the middle of doing my timing belt. I have the tick mark lined up on the accessory pulley, and the two cams look like they are at tdc. However, when I go to put the cam lock bar on, it doesnt line up. It is slightly angled above one of the cams. What should I do?
edit: I took the eight bolts off the accessory pulley. It wont come off. Do I need to take off the big multipoint star in the center that you use to turn the crank?
