I don't know about repair, but if you mean the connector on the harness (from the car), you could always get a replacement for cheap and just splice the new connector on.
A&P usually has them for cheap. Try calling them and see what they say. Great customer service. Then splice the new connector on and seal it with heated shrinking tube. More than likely will not cost you more than like $15 alltogether.
I helped a person source connectors for my OEM headlights I sold him as he was doing the prefacelift to facelift conversion. A&P sold him all 4 connectors (pasenger and driver's side connectors for low/high beam and turn signals) for like $25 shipped. Other places were ~$100. And all you need is one connector, so should be rather cheap.
But you figure what you are going to do with the relay? A person said that the amperage is 15 for a reason. The reason is that Audi rated that circuit for a certain amount of total wattage. Upping the fuse simply increases the total Volt Amperage (Watts) to handle more wattage used by devices on that circuit. But if you do decide to up the fuse, the cable for that circuit must be rated for the amperage, or you will short out that circuit.
