Results 1 to 34 of 34
Thread: am i chipped?
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    am i chipped?
    so i'm in a new b7 and i see he blacket out his headlight(but left the amber coner lens on) and took the seatbelt chime off... so i thought why not see if he is chipped...
    plugged in my giac flashloader and .... nothing
    remembered from having apr on my jetta.... turned the key on and held down the cruise button. then i see... repeated one flash... then two! this is only if you have it chipped right? it won't flash like that if stock? if that's the case... what for the 93 file... one flash or two?
    i didn't really drive it too hard today prior to this revelation as i don't want and more blemishes on my driving record. need to keep my ins and not have to deal with it goin up too much. so when i took her out for a spin just now.. it felt a bit faster.. but not night and day like my b6 was from stock to chipped mode. does it need time to adjust?
    i think i just saved myself a few hundred bucks!
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: am i chipped?
    93 i think have four settings not including stock
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Three Rings TunaRollZ's Avatar
    Feb 20 2007
    911 TT/A5 3.2L/S4 4.2L
    Sunnyvale CA
    Re: am i chipped?
    with the ignition on, press the read button on the flashloader...you should see it flash any programs that are loaded. then it'll settle on the one it's currently using.
    08 Audi A5 s-line 6MT - new daily
    06 Audi S4 6MT - JHM'ed :)
    01 Porsche 911 Turbo 6MT - some mods ;)
    06 Scion Xa - road trip monster
    Feb 20 2007
    Sunnyvale CA
    Re: am i chipped?
    oh sorry..should've read ur whole post. sounds like u suspect u might have an apr program. never used it, so i wouldn't know there.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    Re: am i chipped?
    uhhh it just flashes in order i believe, I have 2 programs on my APR (stock and 93). When I put on cruise and hold it then it flashes once per second which be my first program (stock) and after 5 secs later then it would flash twice per sec which would be my second problem (93)
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Re: am i chipped?
    I have Stock, 93, and 100....in that order.
    1 flash - Stock
    2 flashes - 93
    3 flashes - 100
    I would also have Valet, but was told by APR that they don't have Valet Mode for the B7's yet. So I'd say it's a safe bet that your 2nd flash is either 91 or 93. I believe they always put Stock on the 1st flash.
    Registered Member Two Rings
    Apr 03 2008
    Cambridge, NY
    Re: am i chipped?
    I have two chips, 93 then stock.......
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Re: am i chipped?
    Sounds like you have APR. But I'm sorry, I don't think there is a way to tell what you have because it only flashes "1, 2, 3" in the order of the programs the person chose.
    I would recommend getting a boost gauge to see if the first program is stock/valet. If not, your two programs are most likely 91 and 93 or 93 and 100... something like that
    Ignorance is bliss.
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    already got boost guage and the rest of my mods that's in my sig minus coils. should be a fun weekend.
    so phrost... you're saying that just because it blinks doesn't necessarily mean i have a chip? does it do that stock? or perhaps maybe it did have apr at one point and when audi cpo'd it... they reflashed? like i mentioned in my first post.. its not that huge of a difference ... maybe i'm just buggin.
    Jan 24 2007
    Wisconsin
    Re: am i chipped?
    No no, I'm pretty sure you're chipped with APR.
    I'm just saying that specific programs don't blink a specific number of times, it just goes in order for what you bought (1 blink, 2 blinks) so you won't know what the programs are for sure.
    For example, I have 93 and 100 octane programs (1 blink for 93, 2 blinks for 100). But had I bought stock and 93 octane programs, stock would be 1 blink and 93 would be 2 blinks.
    Ignorance is bliss.
    Veteran Member Three Rings volcomic's Avatar
    May 10 2008
    B9 A4
    Kirkland, WA
    Re: am i chipped?
    Quote Originally Posted by Johnnie View Post
    No the flashing implies that you have a chip, there's just no way to tell what programs the previous owner had loaded on there. With APR you can choose anywhere between 1 & 4 different programs (stock, 91, 93, & 100), and have them loaded in whatever order you choose. You'll have to visit your nearest APR dealer to be sure what you have on there...
    ◊ 20x10 Avant Garde M590's - Brushed Clear ◊ 255/30-20 Hankook V12's ◊ H&R VTF Suspension ◊ APR Tune ◊ ECS Luft-Technik Intake ◊ ECS Carbon Fiber Front Lip Spoiler ◊ ECS Carbon Fiber Grille Accents ◊ Color Matched Reflectors ◊ 15% Tint ◊ 2 JL Audio 12w6V2's ◊ JL Audio 1000/1 Amp ◊
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    ahh i see what u mean. k i guess i'll try it on 1 blink... and then 2 and see what's what. cars always been in fl so i can rule out 91... guess it's b/w stock, 93, and 100. how would my car run on 100 file with 93?
    May 10 2008
    B9 A4
    Kirkland, WA
    Re: am i chipped?
    I would assume it would run pretty lean because it would be expecting high octane gas, and would most likely be trying to throw a lot more air into the mix to balance it out... I have no clue what that would do as far as what you could feel though.
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    ok is my chip defective? i just went out and tested it..
    1 blink is ok. some good power.. roughly the same as my stage 1+ on my b6
    2 blink feels the same.. if i had to choose a difference maybe slower
    3 blinks... my engine wouldn't turn over
    and i don't hear the whistle that my turbo made in my b6 in boost.
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    Quote Originally Posted by volcomic View Post
    maybe my 1st option is 93... and second is 100. that's why i don't feel much of a difference in power??
    i thought a b7 chipped would be much faster than my b6 with the mods below.
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Re: am i chipped?
    Why not call apr? They should have the information on their database. I would think that your vin number would be enough to let you know if it's chipped and with what program(s).
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    ahh can i do that? didn't know. the only apr dealer by my house is chris green and i hear he charges 150 for fault codes and to clear cels... not wanting to do that. i'll call monday.. damm i mean tuesday.
    May 10 2008
    B9 A4
    Kirkland, WA
    Re: am i chipped?
    One of the options for APR is a security lockout (probably what you have on "3 blinks" which would prevent the car from starting). A chipped 2.0T (without any other supporting mods) sould be at least as fast if not faster than a KO4'd 1.8T... Something's not right if you can't tell.
    Could also be something as simple as a torn DV keeping you from holding boost...
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    do you hear you turbo spool? damm i can't wait till i get my guage installed but that's actually the only thing still on my old car since we didn't have a long enough torx screw
    May 10 2008
    B9 A4
    Kirkland, WA
    Re: am i chipped?
    Yeah, I can hear my turbo really well, but I also have a Carbonio intake which makes it probably 3 times as loud as stock. You should definately be able to hear it though, intake or not. Hmmm
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    yeah, u're right.. something must be wrong.. i didn't have any intake on my b6 and i heard it spool... i had a carbonio on my jetta and itdid more to make that pshhhhhh sound after you let off the gas than make me hear my turbo more. hmmmmmmmmmmmmmmmmmmmmmm!!!
    Jul 21 2004
    South Florida
    Re: am i chipped?
    Definitely give APR directly a call with your VIN. With APR you do have the ability to specify which "slot" you want each of your programs. The default for most folks and distributors is usually in order of performance such as "1=stock, 2=93 octane, 3=100 octane) but this is totally up to the customer and the distributor so you never know what they did. It is technically possible for the #1 slot to be the 100 octane slot and the #3 slot to be stock mode for example. They should have a record of each car so i'm sure you'll get it straight. Congrats on having a nice little free 500 to 900 dollars worth of mods. You will DEFINITELY feel the difference once you're in the chipped mode and running a quality fuel. It's not a small gain.
    cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: am i chipped?
    You also have to give the program you set a little time to adjust. 3 is obviously anti-theft
    -Kris
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    got her all figured out.... i think. after driving her awhile.. the second mode def feels faster than the first. i'm gonna call apr on tues to make sure but i think i'm all set
    i hear the turbo spooling now.. but it's no where near as high pitched as it was on my b6. is that normal with these turbos?
    Veteran Member Four Rings swoardrider's Avatar
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Re: am i chipped?
    Sounds like you may have stock, 93, and anti-theft, in that order
    '06 2.0T S-line Tip
    Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, JHM 2+ tune, JHM 4:1 center diff, 18" Wed'sSports w/ 255/30 Toyo R888 (track), 19" Tenzo-R's w/ 255/35 (street), Stern upper arms, upgraded stereo, Huper tint, RS4 grill, JHM HFC, JHM downpipes,OEM S4 exhaust, track goodies
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    yeah i think so tooo....
    got another apr chip question... i'm looking to buy a testpipe and was wondering if i dont' have the testpipe delete file, can i go into an apr dealer and get it reflashed since i'm not the original purchaser?
    May 10 2008
    B9 A4
    Kirkland, WA
    Re: am i chipped?
    Yep. Free upgrades for life. Stays with the car... You can evidently even sell your APR programming to someone else when you get rid of the car.
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    yeah boi!!!!!!!!!!!!!
    Sep 15 2005
    Norwalk, CA
    Re: am i chipped?
    one thing to note tho, although APR doesn't charge for the updates, tuner may charge you a fee to do the re-flash, especially if you didn't purchase the chip through them in the first place.
    You will need to make some friends or try your luck with that one.
    Peter
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    Re: am i chipped?
    Not if you visit Euro Auto Tuning here in Miami only APR dealer I have seen who does not charge his customers for updates/upgrades.
    Since you didn't buy the chip from him though do give him a call. Just explain your situation.
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    thanks for that info.. the apr dealer a few blocks from my house charges for everything i hear.
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    Re: am i chipped?
    definitely get it checked out by an APR distributor, only they can read the code on there, they have pretty good security on that so its generally undetectable..
    also, theres no way to tell which map is on which blink, because when you buy the chip you can set it yourself, so whatever 3 maps he bought he put in whatever order..
    2008 Phantom Black TQM
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    Re: am i chipped?
    go to an authorized apr dealer and ask?
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Dec 27 2005
    Ft lauderdale
    Re: am i chipped?
    apr says i need to go to an auth dealer and pay $150 to do a warranty transfer before they can tell me whats on the chip. guess i'll wait to get my testpipe on n if there's a cel then i'll go.. otherwise, screw it
