Results 1 to 4 of 4
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    Suspension Question!!! (again)
    I'm currently looking around for a used suspension for my 3.0.
    If using a spring and shock setup, is it ok to get a setup that's been on a 1.8 or do i need different springs to accomodate the extra weight of the 3.0? Also, if i were to find a used set of coilovers, would the same rules apply?
    There's alot of info on suspensions but it's usually for the 1.8, hope you guys could make this a 'lil bit clearer for me.. thanks
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Re: Suspension Question!!! (again)
    I'm pretty sure when buying CO's you have to specifiy the motor. I would imagine it matters, what brand are you looking into ?
    Dec 24 2007
    New York, NY
    bilsteins...
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    you need application specific springs and shocks to compensate for the heavier v6 motor.
