Results 1 to 9 of 9
    Registered User Four Rings Dion@Achtuning's Avatar
    Jul 01 2008
    ACHTUN!NG | B6/B7 STaSIS Streetsport Coilovers - $100 off!!
    The STaSIS Streetsport Suspension is ACHTUN!NG's most popular coil-over setup and we're dropping the price so even more of you can get in on the deal! This kit is by far the best "bang-for-buck" coil-over kit on the market and offers superior ride quality and comfort despite its performance characteristics.
    List price: $1155.00 | Sale price: $1055.00 *
    These are in-stock, ready to ship!! Click on the image above to be directed to our website for online purchasing or call toll-free - 877.722.4886.
    ... The details for those who like reading. :D
    STaSIS Street Sport suspension kits are designed specifically for each Audi model and configuration. The ride will feel similar to the factory Audi suspension but with more control. In addition to the comfortable ride the Stasis Streetsport coilover kit will stiffen the suspension just enough to improve the steering response and minimize body roll. The spring rate is chosen for your vehicle and driving use. The dampers are custom valved to match the spring rate. This allows STaSIS to provide the quickest reacting suspension available without the harshness often experienced in mismatched systems. The STaSIS Street Sport suspension kit includes the following components:
    • KONI Cadmium Plated, Adjustable Dampers
    • Koni Progressive Springs
    • UHMWPE Spring Perch Bearings
    Many spring and shock combinations lower the car more than most drivers want. Spring and shock combinations are rarely designed to work in concert with the rest of the suspension and thus make for poor handling and ride quality. The STaSIS Street Sport Coilovers give you the ability to choose where you want the ride height to be while giving you the damping control you need.
    KONI dampers are used in the STaSIS Street Sport line. These are twin-tube dampers featuring KONI's Sport valving. Additional features include a corrosion resistant cadmium plated damper body (when threaded), damping adjustability and height adjustability. Rebound is adjustable while the damper is off of the car. STaSIS sets the rebound for these dampers based on countless hours of testing. Most customers find that changing the settings after installation isn't necessary. The UHMW perch bearing makes for easy adjustments by decreasing the friction between the perch and spring.
    Rear dampers feature the same performance as the front dampers.
    Note:
    The rear suspension of of many Audi and Volkswagen vehicles uses a seperate perch for the spring. Due to this design a "true" coilover is not possible in the rear of those vehicles however an adjustable perch is included for height adjustability.
    * Offer good while current supplies last.
    Jul 01 2008
    Re: ACHTUN!NG | B6/B7 STaSIS Streetsport Coilovers - $100 off!!
    Jul 01 2008
    Veteran Member Four Rings gpxluke's Avatar
    Feb 14 2006
    Vancouver
    Is there a kit+setup deal if i drive down to ur shop
    Jul 01 2008
    We have very competitive install rates so yes, please contact us via email to receive an estimate and work out a time for install.
    Jul 01 2008
    Jul 01 2008
    Jul 01 2008
    Jul 01 2008
    This promotion has ended. Website has been updated with new pricing as STaSIS has raised the prices of these kits. Thanks to those who participated in this promotion!
