Results 1 to 25 of 25
    Registered User Four Rings Dion@Achtuning's Avatar
    Jul 01 2008
    ACHTUN!NG | B6/B7 STaSIS Streetsport Coilovers - $100 off!!
    The STaSIS Streetsport Suspension is ACHTUN!NG's most popular coil-over setup and we're dropping the price so even more of you can get in on the deal! This kit is by far the best "bang-for-buck" coil-over kit on the market and offers superior ride quality and comfort despite its performance characteristics.
    List price: $1155.00 | Sale price: $1055.00 *
    These are in-stock, ready to ship!! Click on the image above to be directed to our website for online purchasing or call toll-free - 877.722.4886.
    ... The details for those who like reading. :D
    STaSIS Street Sport suspension kits are designed specifically for each Audi model and configuration. The ride will feel similar to the factory Audi suspension but with more control. In addition to the comfortable ride the Stasis Streetsport coilover kit will stiffen the suspension just enough to improve the steering response and minimize body roll. The spring rate is chosen for your vehicle and driving use. The dampers are custom valved to match the spring rate. This allows STaSIS to provide the quickest reacting suspension available without the harshness often experienced in mismatched systems. The STaSIS Street Sport suspension kit includes the following components:
    • KONI Cadmium Plated, Adjustable Dampers
    • Koni Progressive Springs
    • UHMWPE Spring Perch Bearings
    Many spring and shock combinations lower the car more than most drivers want. Spring and shock combinations are rarely designed to work in concert with the rest of the suspension and thus make for poor handling and ride quality. The STaSIS Street Sport Coilovers give you the ability to choose where you want the ride height to be while giving you the damping control you need.
    KONI dampers are used in the STaSIS Street Sport line. These are twin-tube dampers featuring KONI's Sport valving. Additional features include a corrosion resistant cadmium plated damper body (when threaded), damping adjustability and height adjustability. Rebound is adjustable while the damper is off of the car. STaSIS sets the rebound for these dampers based on countless hours of testing. Most customers find that changing the settings after installation isn't necessary. The UHMW perch bearing makes for easy adjustments by decreasing the friction between the perch and spring.
    Rear dampers feature the same performance as the front dampers.
    Note:
    The rear suspension of of many Audi and Volkswagen vehicles uses a seperate perch for the spring. Due to this design a "true" coilover is not possible in the rear of those vehicles however an adjustable perch is included for height adjustability.
    * Offer good while current supplies last.
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: ACHTUN!NG | B6/B7 STaSIS Streetsport Coilovers - $100 off!!
    what tools do you provide for the rear spring height adjustment?
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by martini View Post
    unless you had a tool that took out the damn spring it doesnt really matter
    but Im assuming you know this already? its nearly impossible to adjust koni rears on the car
    - Clint
    Jul 01 2008
    Your Stasis coil-over kits comes with a spanner wrench that will allow you to adjust height via the adjustable spring perch...
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by Dion@Achtuning View Post
    thought there may have been a better solution. The spanner I have doesn't work very well
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    The spanner works just fine over here.
    SweetnLou!
    Jul 01 2008
    Quote Originally Posted by golgo13 View Post
    x2... And we install one of these coil-over kits just about every other day using the same spanner wrench.
    Apr 29 2007
    Tampa Bay
    Dion PM me the number for that guy who does the center caps please. I obviously lost t. Thanks
    SweetnLou!
    Jul 01 2008
    PM sent!
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    you can adjust them while they are on the car? the full range up and down?
    Jul 01 2008
    Sure can!
    Apr 10 2008
    jakarta
    if im in Port Orchard, can we do Cash On Delivery For B6 Susp ? thanks
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Sure can!
    sorry for all the ? but is it the SAME spanner wrench for the front and rears? my spanner wrench does not fit on the rears very well... I only got one with my suspension..
    im trying to understand why you can adjust yours (seemingly with ease) and yet I cannot adjust mine - same car, same suspsension
    Jul 01 2008
    Yes, same single spanner wrench to adjust both front and rear. It's possible your adjustable collars are seized or at least have enough debris on the threads to keep you from turning, but despite the "curve" of the spanner not being exactly rounded with the same "curve" of both front and rear shocks, we don't have any issues adjusting both with the same wrench.
    Jul 01 2008
    Plenty still on the shelf, ready to ship!
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    works better then Eibachs POS tool
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    I want these so badddd !!!!!
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Veteran Member Two Rings
    Dec 27 2004
    Taiwan/ Bellevue WA
    TTT
    Jul 01 2008
    Quote Originally Posted by du-du View Post
    TTT
    Jul 01 2008
    Jul 01 2008
    Jul 01 2008
    Jul 01 2008
    Jul 01 2008
    Jul 01 2008
    This promotion has ended. Website has been updated with new pricing as STaSIS has raised the prices of these kits. Thanks to those who participated in this promotion!
