    Registered Member Three Rings int2str's Avatar
    Jan 16 2007
    2002 Audi A4 3.0 Quattro (M)
    San Diego, CA
    Angry More electrical gremlins
    So my sun-roof has been possessed for quite some time now and that's an obvious fix (new sun-roof switch).
    But now a new one showed up:
    When my car got very hot (parked in the sun too long) it seems like my driver side window behaves funky for a bit. If I try to roll it up it goes to the half-way point then open again (!???) - even if I keep holding the button.
    If the window still happens to be up, I've seen it go down once or twice on it's own as well.
    I cannot reproduce this easily yet. Seems like it's intermittent and as I said, it only seems to occur when the car got really hot.
    Anybody else have this happen?
    2002 Audio A4
    3.0 Quattro 6-Speed
    RNS-E GPS, MP3 + Bluetooth
    19" VMR RS4 reps w/ Toyo T1R's
    LED tail lights
    Dec 19 2007
    York, PA
    Re: More electrical gremlins
    ^i have the same intermittent problem
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Really you only need to remove and clean the grease out of the sunroof switch, as for the window you might try the same.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Three Rings haroulli's Avatar
    Mar 06 2007
    Audi A6 C7 - BMW X5 F15
    East Coast
    My drivers window does the same but along with a grinding noise. I've reframed from opening it because i know is going brake completely and be left down.
    As for my sunroof it sometime tilts open/close all on its own. It also rattles ALOT to the point were i have to keep the shade back to stop the rattle.
    My car is an 03 A4 1.8TQ with 79k.
    DirtyBrd if you can expand a little more on cleaning out the switches?
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by haroulli View Post
    your window regulator is shot. going to need to replace it.
    as for it coming back down, its the window switch, needed to replace it on my parents car.
