Originally Posted by
rnp614
Do certain cars exhibit the vibration issue? I.e. fwd more than quattro or vise versa?
Do you mean 15 all around for a stock suspension car? Does it cause rubbing or anything if you have bad roads?
Also to the person who just bought some spacers for their Tit car, what bolts did you buy?
15mm for rears, stock sport or nonsport. Rubbing only usually happens if you are lowered (below 26.5in ground-to-fender). Vibration issues are more common in the front especially in FWD and AWD cars "in general" since the fronts have to do so much work (turn, accelerate, brake, etc, and with momentum and added weight up front). If you get good hubcentric spacers, it may reduce your chances of vibration in the front. A couple people have complaints but the majority seem to be ok.
I did not rub with 15mm and oem 17's (while lowered). Rubbed with the same spacers on the 18's (remember its a wider wheel than the 17's) so I had to drop to 10mm.
