VAG-COM Version: Release 409.1-S
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 AK
Component: 1.8L R4/5VT G 0003
Coding: 0016711
Shop #: WSC 78640
2 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 001 - Upper Limit Exceeded - Intermittent
16891 - Idle Control System RPM Higher than Expected.
P0507 - 001 - Upper Limit Exceeded
Readiness: 0000 1100
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 46: Central Conv.
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 16232
Shop #: WSC 63351
1 Fault Found:
01403 - Glass-Break Sensors: Rear
36-00 - Open Circuit
Address 56: Radio
Controller: 8E0 035 195 H
Component: symphony II NP2 0260
Coding: 01001
Shop #: WSC 73472
2 Faults Found:
65535 - Internal Control Module Memory Error
08-10 - Control Limit Surpassed - Intermittent
End --------------------------------------------------------------------------------------------------
*Radio code will not clear
I really don't know where I'm supposed to go from here, because apparently 3rd gear pulls are worthless for logging? I'm still in search of a road to do 4th gear pulls on.
