Results 1 to 20 of 20
    Established Member Two Rings Spirare's Avatar
    Jul 08 2008
    Upstate NY
    Taller 6th gear?
    I'm kind of disappointed in the 6spd (2002 3.0L 6spd).
    I just got it and in contrast the B5 2.8l mated 5 spd the low gears are much better. I'm not getting the point of such a close ratio from 5th to 6th though. I'm still cruising at around 3000-3200 on the highway and there is only a 200 drop in RPMS between 6th and 5th between 75-80 mph.
    Are there any options out there for a taller 6th gear/ Like maybe out of a TDI or something? I want to see lower RPMS in 6th... like 2800 at 80. Thoughts?
    Dec 13 2007
    St Paul, MN
    Re: Taller 6th gear?
    Quote Originally Posted by Spirare View Post
    I just got it and in contrast the B5 2.8l mated 5 spd the low gears are much better. I'm not getting the point of such a close ratio from 5th to 6th though. I'm still cruising at around 3000k-3200k on the highway and there is only a 200k drop in RPMS between 6th and 5th between 75-80 mph.
    Holy! I was pretty sure the 3.0 redlines at like 6k RPMs.
    What did you do to get it running at 3,000,000 RPMS?
    In all honesty I know what you're talking about - It's really meant as a 5spd with an overdrive gear. Your chances of finding a taller 6th gear alone are probably pretty low. However if you replaced the Transmission, that's another story. Be prepared to spend no less than $5000 for that though.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Not sure.. wish us 5spd guys weren't at 3800-4000 at 80... damn that sucks
    Jul 08 2008
    Upstate NY
    Quote Originally Posted by drmeegge View Post
    DOH!!!
    That's my point. It's not like an overdrive at all. It's like the used the same top gear ratio as the B5 and just crammed an extra in between.
    You would cry, you would scream
    If you knew half the things I've seen
    Please please just do as I say
    repent and leave you evil ways
    Jul 08 2008
    Upstate NY
    Quote Originally Posted by pondside36 View Post
    REALLY!? Wow... ok
    My B5 2.8l did 80 at 3000k. The 3.0L has more torque, it should be able to handle a taller top gear.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I'm not
    Gotta love that 2.8L trans on a 1.8 block
    -Doug
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    I'm not
    Im doing it soon, once i find one for a good price.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by GarbatyA4 View Post
    Good luck with that. I got an incredible deal on mine, otherwise I would not have done it.
    -Doug
    Aug 10 2007
    Ontario Canada
    LOL, I need to.
    First gear sounds like a TDI golf, and 3rd grinds bad.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    LOL, I need to.
    Nothing wrong with a TDI golf. My roommate has one and I want a TDI (might be getting a TDI Jetta).
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    40+mpg, what's not to like. They're rising in value also.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I am on the lookout for a 2.8 trans.
    My 5spd so far is great, even at 102 miles with many launches...but I just "get that feeling" that it wont last too much longer 3rd gear sometimes has a notchy feel, like it will eventually start to grind.
    -Sami-
    Mar 21 2006
    Lakeland, FL.
    Just add the 2.8 5th gear to your 1.8 trans, that way you can keep the shorter 1.8 gears and a taller 5th. The 2.8 gears are to long and your car will lose some pep.
    I'm back bitches!
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    i wouldnt mind a lower rpm in 6th either!! i also have the 3.0 6 spd
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Jul 08 2008
    Upstate NY
    I'm now on the lookout for a blown/trashed B5 S4 tranny. It has a taller 6th. Obviously a GOOD tranny would cost a fortune. A trashed tranny would not likely have a bad 6th gear. All this pending of course the demise of my clutch. I'm not going under there without a reason.
    Mar 21 2006
    Lakeland, FL.
    Or just find out what parts you need to do the swap. I imagine just the 2 gears.
    I'm back bitches!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by dirtybrd View Post
    I can definitely feel how 'long' the 2.8 gears are. And my car isn't making anywhere near the power it is supposed to right now (read: tune). We'll see how it feels after I get a new tune. The plus though, is that its convenient for driving in traffic though. I'm always in 2nd or 3rd now and don't go into 4th until I'm on the highway.
    Ideally, in the long run, I do want to use the 1.8 trans with a taller 5th gear. I might have Greg source me a TDI 5th gear and then get new syncros from JHM and rebuild my 1.8T trans. Then sell my 2.8 trans. It'll be easy now that I have a transmission jack and a lift at my disposal
    -Doug
    Mar 21 2006
    Lakeland, FL.
    That's the best way, TDI 5th. I could 200MPH with that tall of a 5th and 8500rpms.
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    who says u need them? lol
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Me and my old back. I've had way too many transmissions slip off a regular floor jack and crush my hands to want to do it again.
    -Doug
