Results 1 to 11 of 11
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    Question "Dipped" headlight
    so the misses was leaving for work this morning and when she got in the car and turned the lights on it came up on the dash saying "dipped" headlight. And the light was out. Now my questions are.... is the light being out set off the "dipped" headlight warning? What is a "dipped headlight" ?
    Are they connected at all?
    When i get the car infront of me tonight what should i look for? Any advice on this would greatly be appreciated!!!!
    thanks
    jesse
    B8.5 S-line prestige
    #fourringarmy
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    Re: "Dipped" headlight
    dipped headlight= blown headlight bulb
    ReVO BT and a bunch of other stuff
    Feb 26 2008
    none
    BALTIMORE
    Smile Re: "Dipped" headlight
    Quote Originally Posted by 3thrd_a_4 View Post
    OK... so that is all it means? I was worried about possible auto leveling bullspit and stuff like that.... I was thinking something more mechanical, but that is good to know just swap out the bulb and hopefully that will do it.
    thanks for the quick response!
    #fourringarmy
    Jun 08 2008
    Calgary AB Canada
    Theres a dip beam and a high beam, so the "dipped" doesnt actually imply that is burnt out, but that its your dip beam that is out
    Just a little clarification for anyone that might be interested
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Is this the symbol with the light with three slanted lines coming off it? I thought that meant there was a fault in the headlight system.
    -Tim
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Sometimes the connector under the bulb comes loose when you hit a bump; rare but it happens.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Yup if its not the bulb itself then it will be that there is no electrical connection to the bulb so you'll have to tighten the little connector thingy. I guess try that first and if thats not it then its probly the bulb.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Registered Member Two Rings
    Aug 27 2008
    Tennessee
    I had the same thing happen. I just bought my A4 and haven't messed with anything really. There was a storm here (along with the rest of the east coast) and water got into the passenger headlight and blew one of the xenons. People said they would be expensive, but jesus. Dealer wanted 236.00 for one bulb +50.00 for labor. Nearly 300.00 to replace one bulb... If you have xenons, the part number is D1S. You can get 2 on ebay or other internet stores for 100.00. Mine should be coming tomorrow or monday.
    Also, dealer told me that it could be the igniter that is out, not the bulb. Igniter runs about 400.00.
    Feb 26 2008
    none
    BALTIMORE
    thanks everyone!!!
    i will find out when she gets off work tonight....
    #fourringarmy
    Aug 26 2005
    Quote Originally Posted by Mr.Audi View Post
    thanks
    jesse
    "Dipped" = Low Beam headlight, and is the "English" term for "Low Beam".
    The context is that the "High Beam" is the Normal or Main headlight, and is the mode used most of the time, as a historical perspective.
    Aug 27 2008
    Tennessee
    My headlight turned itself back on today... O.o
