Results 1 to 8 of 8
    Senior Member Two Rings madchemistnj's Avatar
    Feb 28 2006
    2005 S4. JHM tuned
    nj
    Once at operating temp car won't stay lit at idle--walbro fuel pump?
    Okay so im driving into the Bronx hoping the Yankees actually win against Boston (go Giambi).
    On the way in the car is working just fine as usual until we hit some rare George Washington Bridge traffic.
    Then the car starts stalling out when idling. I need to keep blipping the throttle to stay lit. 45 min of avoiding stalling on the Cross Bronx exp is just a little stressful. But e brake, clutch and heal toe practice is always worthwhile. Const 2000 RPM didnt even help only stayed lit if it was driving at 20+ mph or varying throttle/rpm.
    car had 1/3 tank of gas and there were no CELs It was hot out (82ish).
    Higway driving car works fine. Started to happen again later on town roads and at lghts. Filled the tank to the top and haven't been able to replicate the problem.
    Question:
    Is the pump overheating?
    Is the pump dying?
    Could it be that one of the hoses is cracked an air is getting into the lines?
    My set up is the following:
    2001 S4 with K03's MTM ECU tuned for dps and 5 bar fpr, walbro 255 lph pump in a Audi 100 basket, labree dp (sans heat sheilds).
    Any insight would be greatly appreciated.
    thanks
    Jason
    embrace the possibilities of a completely blank slate
    2005 S4 JHM tuned
    7 sec '32 Bantam
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Once at operating temp car won't stay lit at idle--walbro fuel pump?
    Wish I could help you, bump for an answer.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    altenator? battery?
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Alternator/battery loose connection - or dying/dead?
    Check your volt gauge, should be in and around 14V during normal driving/running. Check/listen underhood for anything out of the norm.
    Fuel pump may have a bad connection somewhere...hard to say.
    Good luck!
    Brilliant Black 2001 S4 - 6MT <3
    Feb 28 2006
    2005 S4. JHM tuned
    nj
    pretty much isolated the issue to fuel delivery. Everything else checks out okay right now.
    It was really acting like it was starving for fuel. I've pulled the Walbro pump and tested it and its pulling the standard amp at 12v, but it does start to warm up pretty quickly. The stock pump barely changes temperatue when running. It does however suck up a lot more current (it was going bad).
    Fuel filter was okay, not great but no where near as bad as I have seen in other cases.
    Has anyone used the Bosch 040 pump? Or is the 044 the only one worth using? I like the 040 as it has an open bottom.
    2005 S4 JHM tuned
    7 sec '32 Bantam
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    i'd check your injectors as well. Run vagcom and see what codes you get. when you pulled the pump did you make sure there wasent anything blocking the filter
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by madchemistnj View Post
    Feb 28 2006
    2005 S4. JHM tuned
    nj
    UPDATE:
    044 pump is enroute!! with the help of a few key folks I was able to pull together what I needed to install an 044. Installed a new fuel filter. The old one was tough to blow through, but nowhere has hard has I seen them in the past.
    I ran an output test on the injector and they all seemed to click the same. No codes so we'll see.
    thanks
    J
    2005 S4 JHM tuned
    7 sec '32 Bantam
