Results 1 to 4 of 4
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Tit pkg wheel + spacers ?
    Just wondering what spacers i would need to flush them out. All the threads i see are for the stock 17in wheels.
    I measured and 1in in the back and .5in in the front will flush them. Anyone actually have spacers on their tit pkg a4?
    Jun 14 2005
    Anaheim, CA
    Re: Tit pkg wheel + spacers ?
    Im not sure what sizes to recommend but i do have a recommendation you go with high quality spacers such as H&R.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Jan 10 2007
    VA
    10mm front. 15mm rear. no rubbing or adverse affects. get H&R since they make hubcentric spacers specifically for OEM Audi/VW wheels, which = no bad vibrations.
    make sure to get longer lug bolts. stock are 28mm. add the spacer size to 28 to determine the correct bolt/spacer combo.
    Established Member Two Rings hammer.time's Avatar
    Aug 27 2008
    Macan S, 981 Cayman S
    Phila.
    if u order from h&r they should have a spacer plus lug bolt combo with the correct length lugs. I bought a set for my g35 to push out my works even farther def worth the money
