Results 1 to 18 of 18
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Retrieving Radio Code
    Ok, so my battery died the other day from the car sitting and now I need a radio code. Apparently the only way to get the code is for Audi to rape me for $100 by scanning the car and submitting the code they get online with Audi and then they can receive the audio code. Can you retrieve code with VAG-COM or is there any other way??
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Retrieving Radio Code
    Its in the owners manual, but I'm guessing you know that and dont have it.
    Hopefully there is an audi tech on this forum or one of the other audi forums that will look itup for you and give you the code.
    I had bought a radio from someone and I had a friend who was able to look up the number in a book from audi.
    But you will need to supply the number on the back of the radio to retrieve the code.
    I dont think that shows up in vag- but honestly I have no idea if that shows up or not in vag.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Apr 25 2008
    Baltimore
    Yeah, VAG-COM says no. A couple reliable sources said the only way was to scan, and that I can't just pull out the radio. Oh and the previous owners had lost the manuals.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by nateS4 View Post
    You need the AUZ number off the radio and your VIN and the dealer will run it for you. Bring your registration too. The radio has to be pulled to get the AUZ number. Some say it's in the spare tire well..mine isn't.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    pretty sure there is a way to get the code with the vag com if it was unlocked, but wont help in your case.
    Apr 25 2008
    Baltimore
    Quote Originally Posted by mholme View Post
    Yeah, we checked the wheel well and no luck. I tried to do it that way with me getting the # off the radio, but they said they can't do it that way. Probably bullshit, but now it's over there to get $99 radio code.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Apr 25 2008
    Baltimore
    ^^^ Thanks for everyone's help. Sometimes you just have to pay to play I guess.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    PM this individual ('quattro16') and he can get you the radio code if you have the VIN & AUZ number. Worked for me (http://audizine.com/forum/showthread.php?t=224198)
    -Doug
    Apr 25 2008
    Baltimore
    But the car is @ the DEALER now . At least I will have the radio code for next time the battery dies.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Aug 06 2008
    Canadia
    you mean "stealer"
    Apr 25 2008
    Baltimore
    Quote Originally Posted by MacDaddy View Post
    you mean "stealer"
    Oh you don't even know....so after my I got my car yesterday they were nice enough to only charge me half as much, however now my center gauge cluster (the big digital one) doesn't work.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Apr 25 2008
    Baltimore
    WTF?? What could have they done to the center cluster when they hooked up there diag tool up to my car. It works up until it says the car is OK, then it goes completely blank, turns off I should say .
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Jan 29 2007
    08 S4 00 S4
    MD
    Far right of the windshield washer stalk, bottom side. There is a button. Press it.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    +1
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Apr 25 2008
    Baltimore
    Cool, can you give me a little more detailed info about this?? Like what it looks like and what's it's next. Sorry, I am @ work right now and won't get to check this out till later. Thanks, hope this mystery button works.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Jan 29 2007
    08 S4 00 S4
    MD
    I have no idea what it looks like, but it's the only thing there, can't miss it. Mines been off since I bought the car because the pixels are pretty much all dead.
    Jun 15 2007
    ok look at the stick that turns on the windsheild washer fluid, slide your hand on the botom of it untill u feel a button on the very end of the bottom (not the side or top) and push it
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Apr 25 2008
    Baltimore
    ^^I am idiot, that button was flush and it was at night when I was pissed off and taking it out on the dealer. to both of you and I feel retarded.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
