Results 1 to 14 of 14
    Senior Member One Ring
    Dec 30 2007
    Disconnected hose?
    I just changed my oil and I noticed that there is a vacuum hose unhooked at the front of my engine(2002 1.8T). It comes from the underneath left of the engine and runs across the top of the timing belt cover going towards the right side. I tied it to the top rad hose to keep it off my alternator pulley. It is rubber covered with woven fabric. I can't see where it could connect to. Car running fine and no CE light (yet). Any ideas?
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: Disconnected hose?
    got any pics?
    [IMG][/IMG]
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    your probably thinking of the line coming from the DV
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    or the DV Vacuum hose..
    Dec 30 2007
    Thanks for that picture but it doesn't look like my engine.
    Dec 30 2007
    You mean coming from the DV underneath? Going to where then?
    Mar 31 2004
    CA
    thats what i said :)
    the DV line goes up to the n249 valve, located under your intake manifold.
    and if you have an 02 1.8t that is your engine diagram.
    Dec 30 2007
    OK. I need help then. Can you tell me the number of the line in the diagram?
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    here is a pic from a4mods.com with the intake manifold off. The hose goes to the bracket that is laying there with the numbers on it.
    In the diagram posted above the hose runs off the DV(#21) and connects to your n249 valve(#17).
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    dv to #17...if that looks like your engine
    Dec 30 2007
    Thanks guys. I hooked it back up. Does it just slide on with no clamp? Thanks again.
    Mar 31 2004
    CA
    yea, you wont need a clamp or anyhting... just put in on and your good to go :)
    Dec 30 2007
    Super. Thanks again.
    Aug 28 2007
    I would put a clamp on it. Or at least a zip tie. If it fell off once, it can do it again if there is nothing holding it on.
