Results 1 to 40 of 62
    Senior Member Three Rings GhostSquadGarage's Avatar
    Jul 05 2008
    SLR32 \ IS300
    GSG Motorsports SMIC PIPING HAS ARRIVED !!
    You want it and here it is !!
    I will get a few better pics that aren't on a marble floor up soon !
    We're going to be having a Labor day week sale of 10% off only for AZ members and Laurence will set you up with the entry code for whatever you want to purchase from GSG Motorsports !!
    FILL HIS PM BOX AND FILL HIS VOICEMAIL !!!
    mwahahahahah
    DUH! an Audi
    los angeles, CA
    Re: GSG Motorsports SMIC PIPING HAS ARRIVED !!
    wayyyyy jealous!!!!! GSG making it happen!
    marble floors! dang! haha
    -randy
    Jun 18 2008
    oooooo those look goooood.
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Forgive my newbieness, I know FMIC, but is SMIC side mounted intercoolers?
    So is larger piping to run for the stock SMIC?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Jul 05 2008
    SLR32 \ IS300
    Yes, and it's hard aluminum instead of the flexible plastic.
    Will give you 30%+ more airflow and a 1-2psi of extra boost.
    Plus it looks shiny in the engine bay ! hahah
    Jul 05 2008
    SLR32 \ IS300
    Quote Originally Posted by Quattro View Post
    -randy
    Yea I wish those were my floors Freakin Laurence !
    DUH! an Audi
    los angeles, CA
    ^^lol
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by GhostSquadGarage View Post
    So the extra boost is simply attributed to the improved airflow?
    I always thought that aluminum will heat up faster than plastic thereby increasing the temperature of the air inside the aluminum tube more than the plastic would. I guess in this case since the tubing is on the sides of the car it isn't as susceptible to the warm air in the engine bay?
    -Anil
    Jul 05 2008
    SLR32 \ IS300
    Would you rather have limited airflow at 90 degrees or pushing over 30% more air at 93 degrees ?
    The difference in temperature is so minute compared to the advantage of increased air that it's not even applicable.
    Also if you look at your stock piping you'll see the ridges where it's flexible which creates a vortex of air where it will sit for an extended period of time compared to direct flow, and will actually gain temps by not being pushed straight through efficiently.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    10% off everything or just this SMIC? and does that 10% count towards that groupbuy you have going on for the brakes?
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Jul 05 2008
    SLR32 \ IS300
    GB's are already special pricing.
    Usually way more than 10%.
    PM Laurence@gsg for more info on this. He's setting all that up on his end.
    Registered Member Two Rings Laurence@GsG's Avatar
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    10% off everything on the website. Intake pipes whatever you see. intake pipes are free shipping as well. Labor Day SALE
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    Ahhhh, now I don't know if should get a FMIC or the SMIC pipes and an intake pipe. How long will the Labor day sale last?
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Established Member Two Rings hmmd's Avatar
    Feb 07 2007
    2005.5 A4 2.0T quattro
    el centro, california
    you bastards! why must you entice me so?
    ha haa! dangly parts
    Jul 04 2007
    Anchorage, AK / Chicago, IL
    So you did CFD analysis? Or are you just guessing by looking at it?
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    I have a had those in my car ever since I installed my nitrous kit, now in a week of so Im replacing them with silicone ones. The metal ones just get too hot without thermal wrap. You do get more PSI, but the wrapping does not look that good.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Ps, I would not use those claps on plastic, they slip over time and you get a massive boost leak.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings Dangler's Avatar
    PA
    I like this option for those that dont want to or can't run a fmic. I have plans for my non-sline bumper that wont allow me to run a fmic because the piping will get in the way of the mods i plan on.
    F.T.W.L.T.B.D.W.I.C.T.W
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    Quote Originally Posted by HID View Post
    Why would you thermal wrap a pipe on the cold side of the engine? I could understand next to the turbo but why on the tb side? Just a small side note for years the Japanese cars have been using Aluminum piping on intercoolers and such. Also silicone does have degree of flex? Here is one of GsG car that made 832whp on 100 degree day with all Aluminum piping. Only turbo wrap was used on the downpipe. If you look close in the second picture you can see the piping right next to the manifold. I mean if you thermal wrap the cold side piping you should of just heat coated or thremal wrap the intake manifold?
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    Quote Originally Posted by audinoob06 View Post
    Very true plus it keeps the factory warranty safe. Its seems like we keep making new products for the B7 but people keep give us a hard time. We are just trying to offer a good range of new products. The 5 steps we take to making a GSG products. 1. we take a customer car and design the product. 2. we R&D the product on the customer car. The customer picks up his car with the new gsg parts and daily's the car for owner feed back. 3. Customer tells his are her likes and dislikes and we make adjustments. 4. We dyno the car and flow test vs oem. 5. We mass produce the product. We also give the customer the free part they tested. Must of the time we test one product on 3 to 4 cars before we even release it. Just in case of error..
    So each part we make is design and ask for by Audizine members. We are just trying to meet the demand. Just venting..
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    10% off everything code. Type Audizine at check out. www.ghostsquadgarage.com Also free shipping on the Intake pipe and Side SMIC Piping.
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    damn even with 10% off that is still pricey..... looks awesome though.
    oh and guys i installed my tip pipe and that thing is amazing. sound, build quality, the whole package.
    two thumbs up to gsg... keep 'em comin!!
    B8.5 S-line prestige
    #fourringarmy
    Jul 05 2008
    SLR32 \ IS300
    What are you planning ? S6 LED's ? Cause our FMIC fits with those installed as well
    Plus the fact that this retains your factory warranty is a HUGE plus for alot of people.
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by Laurence@GsG View Post
    I was going to thermal coat it, but Venair is making me a kit completely out of silicone, so its only powder coated and warped. However those pressure claps tend to slip out of place when they are connected to plastic parts like the connections on our side mounts. Regular claps work much better. I have had been playing around with this for months now, and the only way that those pipes stayed in place was with regular claps. If it was on metal, I would use the one on the picture no doubt.
    PS. Why do you only have 2 if the system uses 3 ?
    -EI AL CAI.
    -Driver Mod.
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    If that is problem you have found with them slipping off we will give the customer both claps normal hose claps and Tbolt if its and issue.
    Jul 05 2008
    SLR32 \ IS300
    The 3rd one is part of the frame and there's no way a customer is going to hack that out.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    looks like another fine product from gsg. is this a quick diy project like the intake tube or do you have to really open it up to switch these out?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Jul 05 2008
    SLR32 \ IS300
    Well it "can" be done by just removing the under plastics.
    The hot side pipe is easiest to do just remove the front bumper, then it makes the other side easier as well, but it can be done in about an hours time if you know what you're doing.
    Prolly about 2hrs if you don't know where all the screws for the bumper are ;)
    Jul 26 2008
    Black A4 2.0t S-line 6mt
    South Florida
    Hey guys newbie here (not to VAG cars just the Zine), just chyming in cuz i need some help. On the fence with FMIC due to threads like this one. 30% more efficiency from stock SMIC's plus you guys (GSG) make an intake pipe for our cars?...that's gotta be good for some gains as well, no? I understand that you guys do real world testing but could I be so inclined as to ask for some graphs or logs with detailed before and after...IAT differences and/or whp/trq gains across band. This would really seal the deal for me and you would have an order placed ASAP.
    PS...Even a little customer testamony would help...so you guys running their products (GSG) please feel free to chyme in. Thanks in advance.
    Jul 25 2008
    Audi S5, Z06, Supra
    Corona
    Quote Originally Posted by a4fsi View Post
    Alot of people have our products. I'm more then sure some will chime in with testamony. Also check out the gsg intake post and see the 5 pages of feed back and reviews and stuff.
    Jul 05 2008
    SLR32 \ IS300
    Trying to schedule dyno time right now, but nobody wants to work the weekend :(
    Airflow is increased as stated and there's a temp graph in the FMIC Groupbuy thread, just look in my sig for that and hit us up with any other questions you have !
    There's a lot of people using the intake and 2 have the FMIC installed thusfar and a few I've shipped out but haven't heard back as of yet.
    PA
    you guys are putting a lot of time and effort into making products for our cars, that i don't see any others making, aside from the fmic. I dont understand the lack of appreciation. Some of the people on these boards are a bit critical. You guys have proven yourselfs with the supra, which is enough for me to put trust in you. thumbs up for you guys..
    btw pm sent.
    Jul 05 2008
    SLR32 \ IS300
    It's okay. Nobody understands what it takes to make something like this, nor do I expect them to.
    It's the applause and recognition from people that buy and are truely happy and feel it was $ well spent that keeps us coming up with new ideas and moving forward.
    Can't take the good without a little bad.
    Keep it up I see a following beining...
    KO
    EcoLuxuryDetail.com
    6-Speed, Neuspeed Chip, Heat Shield, 034 Intake, Euro Jet PCV, 3" Magnaflow, Test pipe, Sport Suspension, RS4 Sway, Snub mount, Apexi super ground, K&N, RS4 Pedals, Podi, Hawk HPS, Super Blue Fluid, Chrome Mirrors, Clear cornered, Laminx, Debadged, Ziza Led, Xexon Interior, Alcantara boot, Infinity 1000W 12", painted markers, VAG's 19" A8 12 Spoke, 10 & 15mm Spacers
    Senior Member Two Rings sleeprr's Avatar
    Jul 05 2008
    94 90 sedan, 95 318TI....wifes
    Coeur D'Alene, Idaho
    aw...I was so excited to here this news and then realized you guys don't make anything for the a6 :( no love!
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Two things:
    First of all- you have referred to dynos but said FMIC.. No hate here as I love your products but just wondering about dynos before/after with nothing changed but the SMIC piping? This is definitely exciting, and hopefully will at least hold me over for the next couple of years. The heatsoak in the 100 degree and humid weather the past few days has made me want to cry.
    Second- I am holding out until the full cold-air intake and intake pipe package are available together. I'm now very interested in this product, too. Any chance I can get a rain check on the discount for when the intake kit is ready?
    And I have to give a big thumbs-up to yall for being so committed, available to this community, and releasing some much-needed products!!
    Jul 05 2008
    SLR32 \ IS300
    ^^^We'll see what we can do about that.
    Perhaps STaSIS 2.0T can help on that aspect as I believe he's ordered the intake\smic setup.
    CAI is just about finished, making some tweaks and then will have a few made in final form.
    Quote Originally Posted by sleeprr View Post
    Ship your car over so I can make it
    I'll ship it back with everything bolted on
    Aug 06 2008
    Canadia
    that hard metal piping is going to put alot of stress on the smic's, part of the reason the OEM hoses are rubber and have bends in them is for when the engine moves under acceleration and engine braking it won't push or pull on the intercoolers.
    Jul 05 2008
    SLR32 \ IS300
    Silicone Couplers have flex, it's not and has not been as issue at all in our R&D.
    Guys we test this stuff to DEATH on multiple vehicles for thousands of miles, come on now.
    Mar 12 2008
    New York
    I have not pulled the trigger on a GSG product but have been following these treads closely. The guys at GSG really have impressed me by taking on the B7 and their product looks great. The fact that GSG trolls this board is a testament regarding their commitment to our model. Thanks guys and I can't wait for future products..........wanna sponsor an East Coast avant?......
    High fives to you GSG and once that CAI kit comes out, you'll have another customer.
