Results 1 to 23 of 23
    Senior Member Two Rings p.tony's Avatar
    Sep 02 2007
    2000 s4 Stage 3, 1997 Lexus sc300 na-t, 2004 Touareg v8, 2007 Corvette
    Baltimore, MD
    K04 upgrade question???
    I was told that a exhaust upgrade is necessary to support K04/RS K04. That the stock exhasut creates too much back pressure. Is it absolutely necessary or just a favorable suggestion? Just looking for others input and if you run stock exhaust. Just doing a lil more research
    00 C5 2.7t //Stage 3//
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Re: K04 upgrade question???
    Quote Originally Posted by p.tony View Post
    Seriously man not to be an asshole but come on and search
    2010 Brilliant Black/Magma Red S4
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    umm... i guess you could keep your stock exhaust but if I was you I would find a used one for cheap. Stock exhaust really doesnt cause much back pressure however, the downpipes do. If you go K04's it would be absolutely necessary to gut out your precats (which would cost hardly anything) or get a set of uber expensive aftermarket downpipes.
    J Fonz Stage II+
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    or buy the SSAC turboback system... lol
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Quote Originally Posted by JD797 View Post
    he has an a6, i dont think they make one for that car.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    i have never heard of "having" to gut your precats if you go stage 3. THat dosent even make sense. Theres a few stage 3 guys running all FOUR cats with no problems.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by S4 in_lowplaces View Post
    Apparently, there are people who do this..but why for the love of gawd would you not at least gut the stock ones and make piggies? Motor's already out and it's never going to be easier to change them than now. And if you spent all your loot on the stage 3 stuff, at least these won't cost you anything.
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    You're going to need an exhaust. Shoot me a PM and I'll help you out.
    May 30 2007
    Of course it makes sense. That's just as stupid as not doing rods with GT28s. K04 tunes run a lot more boost than they were intended for, which is ~17psi. Having a solid piece of ceramic honeycomb shit a few inches downstream of turbos that are pushing ~25psi can really trap a lot of heat and back pressure in there.
    J Fonz Stage II+
    Feb 09 2006
    Huntington Beach
    Yes, i understand what your saying, but it isnt "necessary". You can run a stage 3 car with all cats in place and be fine. Also, increased heat isnt a bad thing when it comes to your exhaust.
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Increased heat can definitely cause premature failure from turbos. Especially when running a higher than stock boost.
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Sep 02 2007
    Baltimore, MD
    More than likely i will be doing stage 3-. If it helps any. Ive already got the piggies done. Im looking into a 2.5" custom exhaust with resonators. It just might not be immediately after the turbo install.
    Sep 02 2007
    Baltimore, MD
    Nate S4 where in baltimore are you?
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    this is a stupid discussion. I mean come on... if you're going through all the trouble to pull the turbos, why in your right mind would you not slap on some DP's or AT LEAST gut your stock dp's ("Piggies") while you're in there...???
    OP, STFA's a little...
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Sep 27 2007
    hate on me <3
    Quote Originally Posted by nateS4 View Post
    increased heat? haha please, having a catalytic converter would only increase the heat about 200 degrees, and ONLY at the catalytic converter. before the catalytic converter roughly 50 degrees before the cat.
    it would not damage the turbos. you dont need an exhaust. end of story.
    May 30 2007
    Quote Originally Posted by BurnAll4S4 View Post
    You measured it?
    J Fonz Stage II+
    Sep 27 2007
    hate on me <3
    ummm yes daily on vehicles that i work on in my garage. any other questions testing my intelligence?
    Jan 29 2007
    08 S4 00 S4
    MD
    Just get the exhaust when you can. People do run stage 3 with stock exhaust all the time.
    Apr 25 2008
    Baltimore
    Owings Mills. Yeah I got the piggies done as well. Are you looking at a true dual 2.5?
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Apr 25 2008
    Baltimore
    He already gutted his precats anyways and that's what is hard on the KO3s when running higher boost. end of story.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    May 30 2007
    So you daily test the differences in temperatures with running precats vs without? Sounds like you have a lot of time on your hands. I was never testing your intelligence but now I am starting to wonder.
    To the OP: just gut your precats. Only costs a few dollars if you don't have the tools.
    J Fonz Stage II+
    Sep 02 2007
    Baltimore, MD
    Probably throw in an x pipe. Mimicing another setup ive seen in the A6 forum
    Veteran Member Three Rings Silver streak's Avatar
    Jul 14 2007
    01 S4 stage 3 AWE full kit
    Vancouver B.C.
    Just throwing this out there... but who would want their car to sound like a hover vacuum on steroids?
    AWE, GIAC, Stasis,KO4s, bla bla bla this is getting a bit ridiculous. I hope it will end soon.
