Results 1 to 40 of 73
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    So I want to go RWD
    I've read most of the articles, but none have said what EXACTLY to weld on the center diff. It just said to weld it. Could someone say what to weld? pics would be helpful. I was thinking about a stasis 4:1 diff, but I think RWD would just be more badass. I know, quattro is the shit, but after this winter, it won't be seeing any more winters, since it'll be at ASU with me then, and it dosnt snow/rain much down here, so I'll have no use for it. Also, it says just to remove the front axels, but to leave the ABS sensors? how is this done? a full DIY writeup would be sick! thanks
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    Re: So I want to go RWD
    You will be doing the exact opposite if you weld the center diff. Alot of DSM guys do it for fulltime AWD...it helps in launching. My friend did that to his talon and it was a lot better traction wise from a standing start but on a hard turn in a parking lot it would hop and chirp.
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    no use??? for quattro??? pfff, maybe all season tires, but quattro will out-corner most RWD cars any day. It just makes the handling of the car that much better, it's not just for snow and rain
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Quote Originally Posted by JD797 View Post
    I lol'd
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Dec 03 2007
    Potomac, MD
    wat
    Jul 07 2007
    Tempe, AZ
    I do not consider the handling of this car to be good.
    SO how about telling me what to do to make it rwd?
    listen don't convince me not to do this, I just want to do it, and want to know what it takes
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    I really dont know if that would be a good idea. I know that the center differential can be modified beyond a 4:1 but you run the risk of decreasing durability. If you think about a differential, it regulates the distribution of power from the front to the rear. Welding the internals should lead to a 1:1 ratio which like Gen said would be the opposite that you are looking for. Furthermore even if you got it to work, I would think that you would run into problems with the balance and overall feel of the car. Audi designed the chassis and weight distribution with AWD in mind. You might not like the outcome.
    J Fonz Stage II+
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    First off, yea these cars handle like shit but rwd is not going to help the handling. You should work on the suspension of the car to get it to handle better. You want RWD get a mustang.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    May 30 2007
    ^ sorry posted before i read your last comment. Contact JHM and Stasis and see what they say. I am actually surprised that JHM hasn't really had any differential upgrades being that they are so good with transmissions. Maybe taking a gear out of it will cut power to the front
    J Fonz Stage II+
    Feb 14 2004
    Michigan
    saucys4...I'm not genjdm btw, lol
    Senior Member Three Rings XSilverJ's Avatar
    Apr 29 2005
    01.5 Audi S4 Stg.III
    MA
    Honestly I'd like to see someone make an S4 RWD with some power and put some DR's on it and see how it goes..
    -01.5' Audi S4 Stg.III+ - 89' BMW 325ix - 98' Eagle Talon TSi AWD-
    http://i2.photobucket.com/albums/y24.../P42804151.jpg
    AIM: XSilverJ04 / E-Mail: [email protected]
    .:Kinesis//Status//Revo//FiberImages//Duh//Stasis//:.
    Jul 07 2007
    Tempe, AZ
    I don't track the car, and don't really intend on it. I do driving in cities and highways.
    I know i read something about welding a diff.
    Established Member Two Rings Moe's Avatar
    Jan 20 2007
    2000 S4
    Your Mom's house
    Quote Originally Posted by jungb5s4 View Post
    Good luck driving in the mountains during the winter. Remember, Tempe is surrounded by them. So unless you plan on spending all your time in Phoenix or TJ, you're going to wish you still had AWD. If not, then have fun driving your friends civic hybrid to Flagstaff cause' it handles better in the snow.
    -Moe
    MTM chip, 5 bar fpr, 710Ns, H&R/Eibach set up, 034 street mounts, poly snub, piggies, suitcase mod, and oh yeah, K04s and a RS4 clutch.
    Jul 07 2007
    Tempe, AZ
    Quote Originally Posted by XSilverJ View Post
    rwd has been done before, before he was banned for being a giant flamer, Snow trooper was the man to talk to about it.
    Jul 07 2007
    Tempe, AZ
    Quote Originally Posted by Moe View Post
    Good luck driving in the mountains during the winter. Remember, Tempe is surrounded by them. So unless you plan on spending all your time in Phoenix or TJ, you're going to wish you still had AWD. If not, then have fun driving your friends civic hybrid to Flagstaff cause' it hadles better in the snow.
    -Moe
    last time i was here in the winter, there was no snow anywhere. you gotta get up to like sedona or prescott before snow really becomes prevalent. And the last time i drove fwd in winter, i almost died, whereas i drove a friends bmw and enjoyed it...
    Senior Member Two Rings Grey D.'s Avatar
    Jun 22 2008
    Portland, OR
    my brother goes to ASU. Sun Devils FTW...
    Jun 22 2008
    Portland, OR
    also watch out for that speed trap on the 101, people go like 90 and then slow wayyyy the f*ck down.
    May 30 2007
    Quote Originally Posted by revhards4 View Post
    haha oops. i'm too used to just looking at avatars
    J Fonz Stage II+
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Jul 07 2007
    Tempe, AZ
    i saw that thread, but the pictures I thought didn't do it much justice. Is that it to weld? the center part of it? just a few strips of welding?
    Senior Member Two Rings audee3's Avatar
    Mar 15 2008
    montreal,canada
    you just have to weld all the little gears in there together so they are one the more you weld the more solid it will be, mine is welded twice as much as the one in the picture(i own the black one in the video) remove your front axles but leave the outer parts as they are what hold your wheel bearings together and the reason for unplugging the abs is the traction control will keep activating when trying to get it to spin
    Mar 13 2007
    Montreal
    Your not dead bro ?
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Sep 01 2007
    2000 S4
    Columbus, Ohio
    Don't a lot of 996 turbo guys do this? How do they do it, GT2 or 3 parts?
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    LOL
    u r sofa king we todd did
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Apr 22 2007
    Riverbank, Ca
    Ok, Well I post 1.04 continuous G's on street tires on a skidpad.. And I need a full more degree of camber before I can really make use of the tires(only the outside of the tires were getting hot..). I suspect I can get 1.10 continuous lateral G's on a skidpad after cornerbalancing and a little more camber.
    At any rate.. See this thread about RWD..
    http://www.audizine.com/forum/showthread.php?t=231660
    and
    http://www.audizine.com/forum/showthread.php?t=226094
    Just a couple of threads from the A4 boards..
    Apr 10 2008
    wow, i thought that had sarcastic written all over it, apparently not... lol
    Jul 07 2007
    Tempe, AZ
    Quote Originally Posted by andyrew View Post
    and
    i saw that first one, it inspired me to create this thread...
    it's not just the lateral g's that you can pull that determines your car's handling capabilities. I don't doubt that it's a great car, but you have to pretty big suspension mods to get it to handle well.
    Mar 15 2008
    montreal,canada
    almost dead but still hanging on
    Apr 22 2007
    Riverbank, Ca
    Koni coil overs, big rear sway bar w/ metal end links and reinforced sway bar mount, sport front sway bar, a proper alignment and bridgestone RE01-R's. All in all about 500 of tires and 1200 of suspension.
    I spend my time at the autox's and the car is very competitive, one of the fastest street tire cars out there.
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Guys dont you see he wants RWD so he can light up the tires, drift and do some donuts....
    May 30 2007
    Here is some info on a WRX rwd conversion. They used a welding method. http://www.clubwrx.net/forums/powert...wd-w-pics.html
    J Fonz Stage II+
    Account Terminated Four Rings
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    I'm not banned smarty...
    If you actually read my threads on it, I explained it very well. Yet it is possible some stuff is cluttered between multiple posts.
    I just made a new thread on it just for you. Feel special, because when I make a thread just for you, you are!
    http://www.audizine.com/forum/showth...52#post2829552
    Jul 07 2007
    Tempe, AZ
    exactly what i was looking for! thanks dude
    Dec 02 2007
    Sydney, Australia
    whatever drugs your on i want some, i dont know any anyone would want to make an S4 rwd...
    I had a R32 Skyline before the audi pushing about 240rwkw, this thing was fast, but there is nothing fun about going sideways at 120kmh on full boost in the dry, then spinning all the way through 4th gear when its raining...
    Occasionally fun, used to drift it and what not but fark i was spending alot on tyres..
    When it rains im so happy i have quattro powah and i munch anything from the lights, sheet even in the dry i love carving the corners up...
    If you havent already, upgrade the rear swaybar, its cheap and makes a world of difference in the handling... goes from being an understeering idiot to an oversteering legend in no time..
    Quattro > *
    Current
    2005 Suzuki GSXR-1000 Bumblebee | LOR Exhaust |Tinted screen |6000K HID | Chipped & Tuned| K&N Filter| Heaps sick rim tape +25jiggawatts
    2007 Audi A3 2.0T DSG Dolphin Grey| Black Leather| Huge Sunroof| Lots of wheel Spin & A nice exhaust burble....
    Previous
    2000 Audi S4 2.7L Twin turbo-Noggy, Recaros, Exhausted, shiny mirrors, cool bumpers, more power, tints, subs, right hand drive Auzzie Spec...
    Jul 07 2007
    Tempe, AZ
    like previously stated, I don't drag/race at all. I just use it for occasionally stomping dbags who don't respect the 4 rings. I know sooo many people think that it's stupid to do, but these are teh same people who think that every thing that is done on this car HAS to be exactly the same as cars built prior to it. I don't disagree with everything (aftermarket body kits usually suck, fart cans= gayness, ebay headlights are for losers, etc..), but I'm going to be in an environment where generally, there is no weather, and i don't anticipate it going through another winter, minus this one. I want it to be RWD so I can actually accelerate like a 300+whp car should from a roll. I could give a shit about drag launching it. I don't take it on twisty roads (wisconsin was not a place for windy roads, especially southern). I just like to wind the turbos up and get pushed in the back of my seat when I'm crusing.
    I understand quattro is great and everything, I know that, it's great fun, but I know that RWD can be a little more fun in an area where I don't need 4 wheel drive
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    ^^^sounds like it will be fun, thats the whole reason for loving cars and modding. Its your car and money. I would love to do the same thing, and might when I finalize my move. Cant wait to see it when its done. And I have a friend and she is from Beaver Dam.
    Train Hard, Go Hard, But always be Humble.
    Jul 07 2007
    Tempe, AZ
    no shit really? what's her name?
    Senior Member Two Rings SpoolPastYou's Avatar
    Jul 15 2008
    Miami
    can sum1 clear this rumor for me...awhile ago i herd if you hold the esp button down for 10 or 11 seconds it shut the awd off...dunno if they said completely or if it made it a rwd..anyways i tried it in mine..and i held the button..the caution light did actualy flash then turned off and then it wouldnt let me turn the esp back off..i would hit the esp button and the caution light wouldnt stay on...i reset the key and it worked normal again..it was raining when i tried this so i didnt wanna risk anything so i never actually drove out on it..but same thing with my cousins b7 s4
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by SpoolPastYou View Post
