Well, I sent my ECU away to Tapp to get it reflashed with a Maf-Less and SAI-less file for my 71r, and I finally got it back yesterday. Well, after installing, resetting, and doing a throttle body adaption, the car gives me serious problems. It idled like ASS in my driveway (which I expected it to do) so I let it warm up and stabilize a bit. After it did, I dropped the hood.....and all of a sudden, the engine cuts out....????....then I restart the car with the hood closed, let the idle stabilize, and I figured it was okay......then, when I closed the drivers door, the engine shut off once again. I figured it was a battery problem, but my battery is keeping its charge fine according to the volt gauge
Then, once I got the car on the road, driving outside of boost felt normal until at around 2.5k rpms, the car bucked pretty violently and the RPMS dropped dramatically. Meanwhile the EPC and the CEL lights both flickered VERY briefly (not flashing, but like there was an electrical short). So, I quickly try to rev up the engine to keep the car going, but I get no response for about 5 seconds. So I pull over to the side of the road and shut the engine off. When I turn the engine back on, it started up fine. So I started to drive off, and it happened AGAIN. So I went straight home, and emailed Chris and he suspected it might be a bad coilpack. But, after checking my codes and logging blocks 115 and 20, he concluded that there was nothing noticeable....However, i'm not sure it is a coilpack, because my issues doesn't quite feel like a typical misfire. It feels like the engine is shutting itself off, which leads me to believe it could be the speed sensor. But I'm not sure how that could've gone out, because my car has been sitting for weeks while I waited for my reflash, and it was fine before then.
I've done research over on Audiworld, and some people with these systems have either a bad ECU, or a bad engine speed sensor....Anyone got any ideas?
