Results 1 to 6 of 6
    Established Member Two Rings Ravalous's Avatar
    Jun 05 2008
    00 S4 stg3 sold. 93vr6 S/Corrad sold.. MK4 24V Jetta Sold..92 NSX. Pearl white 2001.5 stg2
    Toronto Canada
    Unhappy need help with stg3 asp chip soldering..asap
    I think my neighbor messed up my ecu.. 00 s4, I took my old GIAC ecu out, and was gonna try to have him solder it but it turned out that the car won't start.. I even tried switching the chip from the pins.. I think he might of soldered the legs the wrong way. any help will be greatly appreciated..
    Apr 08 2008
    Toronto, Canada
    Re: need help with stg3 asp chip soldering..asap
    This happened to my Volvo. The chip was soldered the wrong way and not even a software update from Volvo worked. The solution......? Believe it or not, removing both battery cables, touching them together and reinstalling the cables to the battery. It worked.
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
    Active Member Two Rings 1000songs's Avatar
    May 20 2008
    North America
    Quote Originally Posted by lorvar View Post
    Wha? I'm hoping that you can clarify the steps involved before someone blows up a battery and gets covered in battery acid!
    2008 Deep Sea Blue S5
    Apr 08 2008
    Toronto, Canada
    ???? How do you get battery acid on yourself by removing the cables from the battery and tapping them together away from the battery itself? Read what I said again.
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    I can help you out.
    What exactly was done to the ECU?
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    so do you think he soldered it in wrong 180 degres (like top on bottom)?
