Results 1 to 2 of 2
    Awaiting Confirmation Two Rings
    Aug 12 2008
    New York
    cracked upper radiator plastic on radiator
    I was removing my radiator and the upper radiator plastic connection on the radiator itself just simply broke off as I was removing it... I wasn't forcing or prying it out... I was just gently pulling it and the plastic upper radiator connection piece on the radiator broke off.
    Argh--- I'm on the other side of the country... can I simply get the plastic welded? I've heard plastic welding will work for an application like this?
    Any insight guys?
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: cracked upper radiator plastic on radiator
    You could try an epoxy repair after sanding or Permatex Radiator Repair Not sure how well it would work.
    If the piece broke off easily, chances are the plastic is degraded and may give trouble down the road at the worst time. New radiators are under $200 depending on trans, engine and if Q or not.
    ECS has two listed for the V6
