Results 1 to 32 of 32
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    i think i found my new turbo : )
    i have been doing some research and i finally have decided that i am going to go with the Bullseye S362. which should get me to my mid 400whp mark at 22-23 psi. i will take pictures when i get it.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Re: i think i found my new turbo : )
    WOOOOOW, better take out your head light to get that monster in there
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by 102487thedude View Post
    You are better off going with a true Borg-Warner T4 twinscroll S256-30R, full boost (30psi) at 3700RPMs
    Active Member Four Rings
    Dec 11 2006
    Boston
    The bullseye turbos spool faster than the true BW's. And they offer better warranties.
    The 362 should make 400whp fairly easy.
    Stage 3+ RS6's
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by deb38 View Post
    Only because they use exhaust housings with very small a/r's. The T3-S363 comes with a small .70 a/r. It is going to make less power then a true T4 flanged S362 which is equal to a T3/67 turbo.
    The BW's just coming out are their newest design while bullseye uses their older version to make their hybrids.
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Does that run for $1400 or so?
    Apr 06 2007
    yea but it is well worth the money.
    that also means i will get ride of mine for very cheap. who ever is intreasted let me know.
    visit,
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Am thinking of a Turbo like that but next year when I totally fix my car. Turbo is one of the mods I am planning to do. Yes, $1400 will be well worth it
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Good deal, Let us know how things go Blake.
    -Doug
    Apr 06 2007
    no problemi will work on it as soon as i get back to the USA.
    visit,
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    The BW turbos... how do they compare to GT series turbos?
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Jul 07 2004
    socal
    Quote Originally Posted by DELUX View Post
    Some of them have extended tip compressor wheels which allow the turbo to be pushed at much higher boost levels to get get that extra flow.
    They are oil cooled only and are journal bearing.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I just don't like them being T4 flanges, Now it's the cost of a turbo and a manifold.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 07 2004
    socal
    Quote Originally Posted by dirtybrd View Post
    You can buy T3 to T4 flange so you can keep using the manifold you have now.
    This is when having a tube manifold comes in handy, because the flange can just be cut off and a new one welded back on. I am still waiting to get a T4-S366 turbo sent out to me so I can test fit it to make sure it doesn't hit anything. LOL, 82 lbs/min turbo here I come
    Mar 21 2006
    Lakeland, FL.
    I was under the impression from talking to Greg about the S265-30R that they were all T4.
    I'm back bitches!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    But your manifold only cost $300 and you can sell it to recoup some of that cost....
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    s362 should make good power.
    Dec 11 2006
    Boston
    Copy cat.
    Stage 3+ RS6's
    Mar 21 2006
    Lakeland, FL.
    True. If I get this new job the car will be going on jackstands for a do over and I'll buy a Honda/Acura for a DD. One reason I hope SEM comes out soon, but that may not matter depending on how far I take the car...Mike-2ptzero-ish.
    EDITED!!!
    I'm back bitches!
    Jul 07 2004
    socal
    Copy cat.
    LOL, odd aren't you the one trying to be a 1.8T by running a single turbo?
    Quote Originally Posted by Don Supreme View Post
    Yes but how much boost is it going to take to make "good" power on a quattro car.
    Know any 1.8t's making good power with it? Make sure you double check your info before you answer.
    May 28 2004
    Asheville, NC
    Does anybody make anything that uses variable geometry? I heard amazing things about IHI turbos, specifically the VF39 from the US-spec STi, but the manifold options are very costly and euros don't translate well these days into dollars :(
    I'm piecing together a custom build with all the right details and as of now I'm leaning towards the GT28RS or 2871R, but probably the 28rs as I want power earlier. Is it really Garrett or bust for us though?
    Jul 07 2004
    socal
    IHI turbos spin the other way.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    typhoooooooooooon!
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Variable airfoil geometry? Please provide a link. I would like to read up on the turbine and compressor technologies going into automobile turbos. I've done some conceptual design work on variable airfoil geometries for turbines (gas turbine engines). It is used extensively in [gas turbine engine] fans and compressors but mainly from a static (non-rotating) airfoil standpoint.
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    yo man, u wanna trade for the 50 trim and you can just sell that? I should even have some buyers already
    - Clint
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Twinscroll are T4 flanged. This is the sacrifice you make for 1000 RPMs of quicker spool.
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Yea the VTG system in the new porsches.
    You mean this? http://www.worldcarfans.com/2051115.002
    4Runner, Rs5 and Alfa Guilia QV
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Groove1797 View Post
    Thanks. I'll read that article and do some google searching of my own.
    -Doug
    Jul 07 2004
    socal
    I think you mean S256 with the TS-T4 flange. This is a turbo that Full-race has listed up on their site, here is a list of the BW turbos from another site.
    S256 T-3 .58/.76/.85 A/R
    350-550 whp
    *The bullseye version comes in a T3 .55 and .70 A/R
    S258 T-3 .58/.76/.85 A/R
    350-550 whp
    S359 T-3 Twin Scroll .58/.76/.85 A/R
    500-650 whp
    S361 T-3 Twin Scroll .58/.76/.85 A/R
    500-650 whp
    S362 T-3 Twin Scroll .58/.76/.85 A/R
    500-650 whp
    S362 T-4 Twin Scroll .83 A/R
    500-650 whp
    S366 T-3 Twin Scroll .58/.76/.85 A/R
    650-800 whp
    S366 T-4 Twin Scroll .83 A/R
    650-800 whp
    S372 T-4 Twin Scroll 1.10/1.25 A/R
    650-900 whp
    S374 T-4 Twin Scroll 1.10/1.25 A/R
    700-1000whp
    S465 Ti 1.32 A/R .80 A/R Add $300
    650-900 whp
    S471 T-6 Twin Scroll 1.32 A/R
    700-1000+ whp
    S471 T-6 Twin Scroll .80 A/R
    700-1000+ whp
    S475 T-6 Twin Scroll 1.32 A/R
    800-1100+ whp
    S475 T-6 Twin Scroll .80 A/R
    800-1100+ whp
    S480 T-6 Twin Scroll 1.32 A/R
    800-1100+ whp
    S480 T-6 Twin Scroll .80 A/R
    800-1100+ whp
    S595 T-6 1.15 A/R
    1200-1500 whp
    Not all BW S-series turbos have extended tip wheels
    Oct 29 2005
    10speed
    San Francisco, CA
    Greg have you seen proven results of 1000rpms quicker spool?
    - Clint
    Jul 07 2004
    socal
    There has been very few A4 owners that have ran a twin scroll, me being one of those. He might be going by what other people are seeing on cars like the STI and EVO which are already running big turbo setups with twin scrolls.
    Mar 21 2006
    Lakeland, FL.
    I don't really care for a quicker spool, if it gets to early it takes the drivability out of the car.
    I'm back bitches!
