Results 1 to 16 of 16
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Need Help From ER Sport Users
    I need a pic of how your boost sensor is situated.
    4Runner, Rs5 and Alfa Guilia QV
    Apr 08 2004
    Eating Cheese Curds
    Re: Need Help From ER Sport Users
    I guess a better question is... Does it matter what direction the BPS faces?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The plug faces down, if it is on correctly, you will see the ER on the piping
    Apr 08 2004
    Eating Cheese Curds
    Thanks Greg! Got to love retarted shops
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Direction does not matter though But Fred did take the time to have his loge engraved (CNC). Gotta pay the man respect.
    Apr 08 2004
    Eating Cheese Curds
    I still am leaking boost out of the sensor.. spike to 16 then taper to 13. Tried to call already
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Quote Originally Posted by Groove1797 View Post
    Are you sure you screwed it in all of the way? I had a leak right there and then I realized that the sensor could go in further then I thought.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    his was not machined correctly to fit the sensor in flush. I'd be calling up and getting a new section of pipe for free if it were me Tyler...
    Apr 08 2004
    Eating Cheese Curds
    Quote Originally Posted by CO AVANT View Post
    I left them a message last Thursday and once on Monday of this week. Still no call back.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Call the person you ordered the kit from and they shouldn't have a problem getting ahold of fred. I usually have no problem getting fred on the phone.
    BTW are you just having problems getting the sensor in all the way or is the hole too large?
    Veteran Member Four Rings DeanUW's Avatar
    Feb 22 2007
    Lots of stock parts :-)
    Auburn, WA
    Like Co Avant said, probably incorrectly machined. My ER comp and a few others I installed had the same problem. To fix it I bought a baggy of O rings, about the same diameter as the sensor itself, stretched it over the sensor and then bolted it down. The O ring acts like a gasket and seals perfectly. No leaks!
    If you were like me and couldn't leave the car unfinished stop by schucks, and look at their rubber O ring selection. It will be green and come in packs of 10 I believe. Bring the sensor and test fit them make sure it fits snug. GL with whatever you do. ER will take car of you too!
    Deanophotography.com | The A4 (Updated 3/1/10)
    REVO Tuned GTRS Eliminator
    Caractere | Evolution Racewerks | Southbend | STĂSIS | ATP | QTP | Magnaflow | Samco | OEM | VMR | Defi | TurboXS Dtec w/ Gameboy
    Jul 07 2004
    socal
    Quote Originally Posted by DeanUW View Post
    So your stock O-ring wasn't the right size or you just didn't have one on there?
    Apr 08 2004
    Eating Cheese Curds
    The stock O-ring was replaced by Audi to attempt and remedy the problem but there was no luck. I went to checker and replaced the o-ring. The OEM is 8mm ID, 12mm OD, and 2mm diameter. It was replaced with an 8mm ID, 12.5mm OD, and 2.48mm diameter. I have gained about 1psi since I replaced it today. The shop it was bought from closed.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I have new O rings to fix your issues. I can mail tomorrow if you would like.
    Apr 08 2004
    Eating Cheese Curds
    How big?
    Feb 22 2007
    Auburn, WA
    Hard to explain unless I drew it out but too lazy to draw something then host it but basically the whole is the correct size but the hollowed out rib where the O ring is supposed to seal in was torn, almost looked like the CNC machine came out crooked and nicked the edge keeping the OEM O-ring from sealing... This was the case for both ER's I installed a while back. I told Fred about the problem so it probably was taken care of on their current batches.
