I just had an alignment done and was told the rear upper driver control arm bushings are shot. I need to go inspect the rear suspension and confirm.
The service writer also mumbled something about the center diff seal was leaking. I just did the trans so I don't know what they are talking about
When I dropped the Avant off earlier this morning I had a classic Fast Times moment "Don't fuck with it." (but in a polite, non-profane way)
UPDATE:
Just spoke to the tech. The rear upper control arm bushing, the eccentric that adjusts camber is bad. The bolt is frozen in the bushing. I told him I'll replace them when I install the coil-overs next summer.
The tailhousing driveshaft seal is leaking. A seal I never touched. Shouldn't be too hard to fix. I mentioned the tailhousing was off and I 'tweaked' the center diff. "Yeah, I noticed that." Guess he saw that when he was pulling the car in and out of the shop.
Camber was set to -1deg 13mins. Right within spec for my car. They were able to get the rear wheels adjusted to within spec. Should be good to go 'till I do coil-overs next summer. Then I'll re-align to 1.2 or 1.5deg camber.
