Results 1 to 9 of 9
    Established Member Two Rings Sobo's Avatar
    May 14 2008
    S4
    east aurora
    Squeeeeeeeeeek... Suspension problems.
    Picked up a 1997 Audi a4 for my girlfriend.
    1.8t, quattro, Automatic(not tip)
    The car makes a squeaking (sounds like rubber on rubber) noise whenever you turn the wheels while parked.
    I feel like this has to do with the ball joints and its very annoying. What could it bee?
    Thanks
    2000 S4.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: Squeeeeeeeeeek... Suspension problems.
    It's either the ball joints on the control arms, or the tie rod ends.
    Best solution is to replace them all with a complete control arm kit like our Febi-Bilstein one.
    Senior Member Two Rings Side-Step's Avatar
    Mar 05 2007
    Wife's 99.5 Avant,99 Dodge CTD,Wife's 05 S4 Avant
    Charleston, SC, East coast
    could be the swaybar bushings. Spray some lube on the bushings and see if it goes away.
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    also make sure the hydraulic p/s fluid is not too low, its the tank that has a cover on it behind the driver's headlight.
    Nov 15 2007
    Audi A4
    Redding, California
    my guess is lower control arms....the big ones...
    gl!
    May 14 2008
    S4
    east aurora
    Whoever guessed lower control arm was correct.
    The bushing is just torn to shreads by the frame. However all the control arms are new.
    2000 S4.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by Sobo View Post
    How are they all new if the bushing is torn up?
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Nov 15 2007
    Audi A4
    Redding, California
    Quote Originally Posted by B518T View Post
    gl!
    yup....I have the same squeek....replacing mine this week
    just ordered them last night
    Active Member Four Rings HOFFY11's Avatar
    Aug 01 2008
    Audi A6 4.2L Quattro
    forked river, NJ
    tie rod ends
