Results 1 to 19 of 19
    Established Member Two Rings stephengraham's Avatar
    Aug 27 2008
    Fredericksburg, Virginia
    Question Exhaust options for 3.2L V6
    I've spent several days searching to prevent starting a new thread on a topic that may have been covered, but haven't had any results I'm confident in.
    I have a 2005.5 A4 3.2L V6 and have found no solid options for an exhaust that I'm confident actually fit my car. I came across a couple references to the 3.0L exhaust for 02-06 fitting, but none of the manufacturers allude to this.
    I'm at a loss for finding an exhaust that is reasonably attainable. Anyone with information on what will fit my car would be greatly appreciated.
    If nothing else, would simply replacing the resonators with a Y-pipe be a somewhat satisfactory solution? I'm not looking for any performance gains to speak of, only a more defining sound.
    Thanks in advance.
    Veteran Member Three Rings Echo3One's Avatar
    Apr 02 2007
    Phoenix
    Re: Exhaust options for 3.2L V6
    I have a 3.0 AWE exhaust installed on my 3.2. No modification was needed. Cost about $1100 installed.
    2021 Audi RS7 | Nardo Gray | Cognac Interior | Carbon Optic Package |
    |Eventuri Carbon Intake System |Akrapovic Evolution Titanium Exhaust | CETE Active Air Suspension Lowering Module |
    2010 Audi S5, 6-SMT | Meteor Gray | Prestige Package | Magma Red Interior |
    | APR Supercharger | STaSiS Exhaust | STaSiS Touring Suspension | STaSiS Cast Wheels 20 x 10 |
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Drummasta has a non resonated Milltek on his 3.2
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Aug 26 2008
    toronto
    im in the same boat as you but i have a 09 a4 and i want to change the exhasut but nothing toooo crazy would putting a s4 exhuast work? just the axle back even.
    sorry for the thread jackk
    mikey
    Oct 14 2006
    MK6 Jetta
    South,FL
    Milltek is very mild but deep and creamy in tone
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings CONTROL TWO's Avatar
    Oct 01 2006
    Cayman S
    SJ
    3.0 neuspeed = the shit.. its loud though (if you mind)
    -Grant
    ig: g_strachan
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    Downpipe-back section is the same among B6 3.0, B7 3.2, and B6/B7 S4. You might want to look into sound/tone of different exhausts instead.
    sky14, if you meant stock S4 exhaust, it's not worth doing it unless you can get one for free. It's going to sound a tad deeper at idle and a bit louder at WOT.
    Aug 27 2008
    Thanks for the input you guys and for confirming that the 3.0 fits the 3.2.
    Robert Hamme from Stratmosphere responded via email also:
    "The 3.0L and the 3.2L use the same exhaust system. It is in fact a B6 S4 system by Milltek."
    The first I had heard of this was in a comment on this video: http://www.youtube.com/watch?v=kUQCY...eature=related
    I think I will end up with the Neuspeed even though it's hard to judge from varying quality videos.
    Aug 27 2008
    Quote Originally Posted by Ti.S.Line.21 View Post
    The Neuspeed website says it is for manual only, I have the Tip.
    http://www.neuspeed.com/products/pro...&ltype=ns_euro
    Active Member Two Rings Bauer's Avatar
    May 10 2005
    Lafayette, CA
    STaSIS system sounds awesome!
    http://www.youtube.com/watch?v=Vgwi-HfNZZs
    Bauer
    07 A4 2.0T quattro - STaSIS Motor Sports Ohlins, STaSIS Alcon 370mm, GIAC, AWE exhaust, AMS SS, OEM rear DTM spoiler STaSIS high bias center diff
    03 RS6 She will be missed
    01 S8
    01 S4 KO4's, Awe fueling kit, Revlover cams, STaSIS Alcon 6 pot 355 rotors, STaSIS Motor Sports Ohlins, STaSIS LSD, STaSIS 4:1 DIff, STaSIS Custom built trans w/shorter gearing, custom exhaust, Recaro's, RS4 IC, RS4 bumper...ect, ect (Sold to Chip Herr...now she is being properly driven)
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    I have a custom apexi ws2 exhaust...to be honest with you custom is the way to go for 3.2
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Aug 27 2008
    Quote Originally Posted by SGVA4 View Post
    I've never had a custom exhaust made. Would I only need to buy the muffler and ask the shop to make it work or what? If so where can I buy a muffler only from one of these manufacturers?
    Apart from that, does anyone have the stock exhaust with the resonators removed? Would this sound decent? Would a custom shop be able to do this easily?
    Mar 03 2008
    626 SoCal
    Quote Originally Posted by stephengraham View Post
    Magnaflow, Apexi, Tanabe all make mufflers that would look good with our ride. you can chop off the stock and weld the new ones on or you can get piping made from the midpipe down. you can order these mufflers online there are dozens of companies that carries them
    "J Spec B7"
    Oct 01 2006
    Cayman S
    SJ
    tip and manual are different exhaust systems on all B7 systems....
    buy a 3.0 tip system?
    buy a manual?
    -Grant
    ig: g_strachan
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    I did this with my B6.. the sound was perfect. On my b7 im going to put 2 butterfly valves before the resonators so i dont have to cut them out. The car looked naked without them.
    Aug 29 2008
    All the above information is very useful cuz I'm also in the same situation. I have a 2008 A4 B7 3.2L FWD A/T.....I know extremely rare. Will the 2002-2006 B6 exhaust work on my set up since its 2WD? Thanks in advance.
    Aug 29 2008
    Quote Originally Posted by HID View Post
    Oct 01 2006
    Cayman S
    SJ
    why do people buy fwd auto a4's?
    -Grant
    ig: g_strachan
    Aug 27 2008
    What is the diameter of the stock 3.2L exhaust? I'm thinking about ordering the cutout just to try it on, if I don't like it I'll buy into a full exhaust and not feel like I wasted too much money. I looked at Jegs but they have several sizes.
